[mapserver-users] problem in wms service
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 16 05:05:00 PDT 2016
Hello,
I would first be sure to use the 'shp2img' commandline utility to
confirm that a valid map image is generated by your mapfile. Once you
have that map working through shp2img, then move to test your mapfile
through WMS, and most importantly generating a GetCapabilities request.
Be sure to review the GetCapabilities response, and remove any "WARNING"
messages. Once you have a GetCapabilities response with no warnings,
then you can test with a GetMap request.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-08-16 4:07 AM, Ahmet Temiz wrote:
> Hi,
> I am testing my wms, postgis layer it works with QUERY_STRING but not
> displays anything with curl and QGIS.
