[mapserver-users] Filtering NULL values from Postgis Layer in Mapserver 7
deduikertjes
DeDuikertjes at xs4all.nl
Wed Aug 17 02:08:31 PDT 2016
Andreas,
Thank you.
hmm, that's very interesting. Lets see if I understand correctly:
I observe that in the CLASS EXPRESSIONs in a Postgis layer NULL is treated
as zero for numeric fields. So NULL gets visualized in the class where zero
is visualized. In my opinion that is not very desirable. I actually would
expect a default behaviour where NULL values will not match any CLASS
EXPRESSION.
In Mapserver 6 we luckily had the FILTER option to filter out the NULL
values to remedy this behaviour. Not very elegant but very doable.
Now in Mapserver 7 we lost the FILTER option and have to write a subselect
in the DATA statement to get rid of NULL values. That seems to be a rather
complicated solution for something which seems to be a very common task.
Or am I missing something and is there a way to avoid that NULL values end
up as being treated as 0?
MArco
View this message in context: http://osgeo-org.1560.x6.nabble.com/Filtering-NULL-values-from-Postgis-Layer-in-Mapserver-7-tp5280893p5281035.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
