[mapserver-users] How increase the tolerance for GetFeatureInfo over a line dataset
Andrea Peri
aperi2007 at gmail.com
Tue Aug 23 12:10:10 PDT 2016
Hi Jeff,
Thx for help,I resolved it.
It was effectivelly a problem of our client gis
not of mapserver.
I don't remenber of the cache problem of qgis.
Andrea.
2016-08-23 19:23 GMT+02:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> Hi Andrea,
> I have tested a GetFeatureInfo (through a query in QGIS 2.16) with
> TOLERANCE 50
> TOLERANCEUNITS pixels
> and it correctly returns text query results with a large radius. I would
> note that if you are also testing through QGIS, there is a nasty 'feature'
> in the 2.x releases where I must manually delete my cache, if I want to see
> changes in any of my WMS services (for example, after I change my mapfile I
> must delete the contents of the QGIS cache folder).
> I am using MS4W 3.1.4 (MapServer 7.0.1).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2016-08-23 12:14 PM, Andrea Peri wrote:
>> Hi,
>> I have a line dataset and need to allow an easy GetFeatureInfo over the
>> lines.
>> actually is extremely hard for an user to be able to click exactly
>> over the line and retrieve the Information of the feature.
>> So I need to increase the tollerance to the point click.
>> I see from documentation that there is the two values:
>> "tolerance" and "tolerance units",
>> So i try to set both them
>> TOLERANCE 10.0
>> But no effect seem to have.
>> Perhaps I understand wrongly to mean of "tolerance"
>> Thx for every info.
> mapserver-users at lists.osgeo.org
Andrea Peri
qwerty àèìòù
