[mapserver-users] PHP MapScript Installation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Aug 27 06:21:56 PDT 2016
I'll try to see if I can get PHPMapScript to compile with cmake, since I
am "code-sprinting", and file a ticket. I believe I am stuck on this
because I am on Windows (see the many hardcoded unix paths in
FindPHP.cmake). I'll do my best to see if I can stop having to use
custom makes.
If anyone else can help please let me know.
-jeff
On 2016-08-26 5:48 AM, Argyris Margaritis wrote:
> Hi everyone,
> I'm trying to follow the installation steps for the PHP version of
> MapScript, however I'm a bit confused as many of the guides date back to
> php3.
> Currently I was using the following docker image for my tests, which was
> working fine as it is:
> https://github.com/kartoza/docker-mapserver
> <https://github.com/kartoza/docker-mapserver>
> However, to enable PHP MapScript I think I've had to add the
> following to thesetup.sh
> <https://github.com/kartoza/docker-mapserver/blob/master/setup.sh> as a
> cmake option:
> -DWITH_PHP=1
> This resulted in the following error during build:
> CMake Error at mapscript/php/CMakeLists.txt:31 (install):
> install TARGETS given no LIBRARY DESTINATION for module target
> "php_mapscript".
> How should I pass the PHP5_EXTENSION_DIR to cmake?
> Thanks in advance,
> Argyris
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
