[mapserver-users] PHP MapScript Installation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Aug 27 05:58:19 PDT 2016
Hello Argyris,
I package PHPMapScript for Windows users (for the MS4W community), but I
have long faced your same problem. In fact, because of the status of
cmake when trying to build all of the mapscripts, I am forced to
maintain custom makefiles, so that PHP and all other mapscript types
(Python, CSharp) can compile. This doesn't help your question, at all,
but, since I have long been in your exact shoes, I can tell you what I
have found out (and hopefully others can respond as well):
- I closely examined each "FindXX.cmake" file in the MapServer source,
to try to understand how cmake tries to find these settings
- for PHPmapscript, the magic lives at
https://github.com/mapserver/mapserver/blob/branch-7-0/cmake/FindPHP5.cmake
I believe these settings are needed, in your cmake call:
-DWITH_PHP=1
-DPHP5_INCLUDE_PATH="your/path"
-DPHP5_EXECUTABLE="your/path"
-DPHP5_EXTENSION_DIR="your/path"
Maybe since we are all at the MapServer code sprint now, this is a good
time to tackle these mapscript cmake issues. It has been a big headache
for me, maintaining custom makefiles so that mapscripts can compile.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-08-26 5:48 AM, Argyris Margaritis wrote:
> Hi everyone,
> I'm trying to follow the installation steps for the PHP version of
> MapScript, however I'm a bit confused as many of the guides date back to
> php3.
> Currently I was using the following docker image for my tests, which was
> working fine as it is:
> https://github.com/kartoza/docker-mapserver
> <https://github.com/kartoza/docker-mapserver>
> However, to enable PHP MapScript I think I've had to add the
> following to thesetup.sh
> <https://github.com/kartoza/docker-mapserver/blob/master/setup.sh> as a
> cmake option:
> -DWITH_PHP=1
> This resulted in the following error during build:
> CMake Error at mapscript/php/CMakeLists.txt:31 (install):
> install TARGETS given no LIBRARY DESTINATION for module target
> "php_mapscript".
> How should I pass the PHP5_EXTENSION_DIR to cmake?
> Thanks in advance,
> Argyris
