[mapserver-users] How Interval is defined for WMS-T
Even Rouault
even.rouault at spatialys.com
Tue Feb 16 06:43:43 PST 2016
Le mardi 16 février 2016 15:21:17, Yves Jacolin a écrit :
> Hello,
> I have a WMS-T layer. The datasource is in a postgis layer. The SQL request
> send by MapServer is something like this:
> ("timestamp" between date_trunc('second',timestamp
> '2016-02-17T15:00:00.000Z') and date_trunc('second',timestamp
> '2016-02-17T15:00:00.000Z') + interval '1 second' - interval '1 second')
> I understand the + interval '1 second' - interval '1second', but I can't
> understand how the first interval resolution come from, see [1].
> I guess this is calculated from wms_timedefault or wms_timeextent. Here my
> METADATA LAYER of my mapfile:
> "wms_timeextent" "2016-02-16T22:20/2016-02-17T21:20/PT1H"
> "wms_timeitem" "timestamp"
> "wms_timedefault" "2016-02-16T23:20"
> Any idea how I can "force" the interval resolution to minute?
Yves,
The resolution comes from the value of time parameter passed in the WMS
request (or the timedefault value if time is not specified). To get a one
minute resolution, the time parameter must be expressed in minutes. This is
actually explained in http://mapserver.org/ogc/wms_time.html ( "Interpreting
Time Values", "Exceptions to this rule")
AFAICS there's no way to override that currently (although it might
potentially be desirable, for example by taking into account the resolution in
the timeextent syntax)
One workaround to indicate the intent to the client is to specify
"wms_timeformat". Although it doesn't seem to work properly currently, ie if
you specify "YYYY-MM-DDTHH:MM", a value with seconds will be accepted as
validating the beginning of the pattern. Hum looks like a bug.
Even
http://www.spatialys.com
