[mapserver-users] How Interval is defined for WMS-T
thomas bonfort
thomas.bonfort at gmail.com
Tue Feb 16 06:54:20 PST 2016
Even,
I'm not sure I agree with your conclusion.
I think the intention would be to write
timecol between time0 and time0+resolution
which translates to:
time0<=timecol<=time0+resolution
whereas we want:
time0<=timecol<time0+resolution
thus the hack to use time0+resolution-1second which is clearly incorrect
when the desired resolution is the second (and somewhat incorrect for the
other resolutions)
I'd say this is a bug.
thomas
On 16 February 2016 at 15:43, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 16 février 2016 15:21:17, Yves Jacolin a écrit :
> > Hello,
> > I have a WMS-T layer. The datasource is in a postgis layer. The SQL
> request
> > send by MapServer is something like this:
> > ("timestamp" between date_trunc('second',timestamp
> > '2016-02-17T15:00:00.000Z') and date_trunc('second',timestamp
> > '2016-02-17T15:00:00.000Z') + interval '1 second' - interval '1 second')
> > I understand the + interval '1 second' - interval '1second', but I can't
> > understand how the first interval resolution come from, see [1].
> > I guess this is calculated from wms_timedefault or wms_timeextent. Here
> my
> > METADATA LAYER of my mapfile:
> > "wms_timeextent" "2016-02-16T22:20/2016-02-17T21:20/PT1H"
> > "wms_timeitem" "timestamp"
> > "wms_timedefault" "2016-02-16T23:20"
> > Any idea how I can "force" the interval resolution to minute?
> Yves,
> The resolution comes from the value of time parameter passed in the WMS
> request (or the timedefault value if time is not specified). To get a one
> minute resolution, the time parameter must be expressed in minutes.
> This is
> actually explained in http://mapserver.org/ogc/wms_time.html (
> "Interpreting
> Time Values", "Exceptions to this rule")
> AFAICS there's no way to override that currently (although it might
> potentially be desirable, for example by taking into account the
> resolution in
> the timeextent syntax)
> One workaround to indicate the intent to the client is to specify
> "wms_timeformat". Although it doesn't seem to work properly currently, ie
> if
> you specify "YYYY-MM-DDTHH:MM", a value with seconds will be accepted as
> validating the beginning of the pattern. Hum looks like a bug.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160216/eef4da65/attachment.html>
