[mapserver-users] Label not Displaying at Edge of Map Extent
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Wed Feb 24 06:09:53 PST 2016
Michele,
I am guessing that if you set LABEL PARTIALS to TRUE (or just comment it out), you will see your label.
http://mapserver.org/mapfile/label.html
David.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michele Toma
Sent: Tuesday, February 23, 2016 7:14 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Label not Displaying at Edge of Map Extent
Hi everyone,
I am having an issue with getting a label to display when it is near the edge of the map extent. From what I have seen, when I attach the style for the icon to the label object, the label does not display. However, if I remove the style for the icon from the label object, it does display. Is this an issue with MapServer 7 or the settings that I have used?
Version Information:
[root at Map18-03 cgi-bin]# ./mapserv -v
MapServer version 7.0.0 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Below is the map file to reproduce the issue. Please note that there are two layers - one without the icon style attached, and one with the icon style attached. The layer without the icon style attached has been turned on while the other is off.
MAP
EXTENT -87.919802 0.000000 72.177555 90.000000
SIZE 1280 720
IMAGECOLOR 140 140 140
SYMBOL
NAME 'Airport'
TYPE ELLIPSE
POINTS 1 1 END
FILLED true
END
LAYER
NAME "Label does display (no icon)"
TYPE POINT
FEATURE
POINTS
-87.9 41.983333
END
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
END # PROJECTION
STATUS DEFAULT
CLASS
TEXT 'Label'
LABEL
TYPE BITMAP
SIZE 20
COLOR 255 255 255
PARTIALS FALSE
POSITION AUTO
PRIORITY 10
END # LABEL
END # CLASS
END # LAYER
LAYER
NAME "Label does not display (with icon)"
TYPE POINT
FEATURE
POINTS
-87.9 41.983333
END
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
END # PROJECTION
STATUS OFF
CLASS
TEXT 'Label'
LABEL
TYPE BITMAP
SIZE 20
COLOR 255 255 255
PARTIALS FALSE
POSITION AUTO
PRIORITY 10
STYLE
SYMBOL "Airport"
COLOR 0 255 0
OUTLINECOLOR 0 0 0
SIZE 20
END # STYLE
END # LABEL
END # CLASS
END # LAYER
END
Thank you,
Michele Toma
michele.toma at airborne.aero<mailto:michele.toma at airborne.aero>
www.airborne.aero
[New Small2]
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160224/129c4435/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160224/129c4435/attachment-0001.jpg>
