[mapserver-users] How to set queryable=1 for a GROUP layer?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Jan 4 07:43:53 PST 2016
I have a layer group, let's say "group_1", where all the sub-layers are queryable. The group layer is also effectively queryable and GetFeatureInfo works if I use &QUERY_LAYERS=group_1. The problem is that the group layer is not announced announced as queryable in the GetCapabilities
<Layer>
<Name> group_1</Name>
<Title> group_1</Title>
<Layer queryable="1" opaque="0" cascaded="0">
<Name> sub_layer</Name>
I would like to see it as:
<Layer queryable="1">
Without queryable attribute I can't make GetFeatureInfo to work when I am cascading it with Geoserver. By reading the WMS 1.1.1 standard I feel that GeoServer is behaving as it is supposed to work: if the layer is not announced to be queryable then it is not queryable. I can't find any mention in the WMS standard that a group layer should behave in a different way than the normal layers.
7.1.4.6 Layer Attributes
A <Layer> may have zero or more of the following XML attributes: queryable, cascaded,
opaque, noSubsets, fixedWidth, fixedHeight. All of these attributes are optional and
default to 0
7.1.4.6.1 Queryable layers
A Layer is said to be "queryable" if the server supports the GetFeatureInfo operation on
that Layer. A server may support GetFeatureInfo on some of its layers but not on all. A
server shall issue a Service Exception (code="LayerNotQueryable") if GetFeatureInfo is
requested on a Layer that is not queryable.
Is there any way to add the queryable="1" attribute to a layer group?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160104/2791d837/attachment.html>
