[mapserver-users] Rendering VMAP1 & VMAP2 in VPF Format
Francis, Mike
mfrancis at srcinc.com
Fri Jan 29 05:55:13 PST 2016
Good Morning,
What is the easiest way to load Vector Maps (VMAP1 & VMAP2) into map server. From what I have read vector maps need to be converted into a shape file and then a layer needs to be defined for that shape file. I have created a script that takes set of VPF files and creates a point, line, area, and text shape file. From that point I am able to create a layer that is able to render lines and points. I have not been able to get areas and text vector data to display anything. Does a layer require a special property to render area and text? Is there an easier way to render VPF data?
Thanks,
Mike Francis
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160129/802acdbe/attachment.html>
