[mapserver-users] Mapserver as WMS on Windows
bimuellererwin
erwin.bimueller at lkee.de
Fri Jul 29 05:25:50 PDT 2016
Hello,
I am trying to set up MS4W 3.1.4 on Windows Server 2008 R2 Standard as a WMS Server for internal use of the WMS. I have successfully installed Apache, created a mapfile with a layer and I am able to post requests to Mapserver. My mapfile has the following content:
# Mapfile fuer die autarke Darstellung von Rasterdaten fuer den Katastrophenschutz im Landkreis Elbe-Elster
MAP
EXTENT 345000 5682322 440000 5754034
FONTSET "D:\ms4w\Apache\Fonts\fonts.list"
IMAGECOLOR 255 255 255
IMAGETYPE png
SYMBOLSET "D:\ms4w\Apache\Symbols\symbol.sym"
SIZE 600 500
STATUS ON
UNITS METERS
NAME "Rasterdaten autark"
DEBUG ON
OUTPUTFORMAT
NAME png
MIMETYPE image/png
DRIVER GD/PNG
EXTENSION png
IMAGEMODE RGB
TRANSPARENT FALSE
END
PROJECTION
"init=epsg:25833"
END
LEGEND
KEYSIZE 25 15
KEYSPACING 5 5
LABEL
ANGLE 0.000000
ANTIALIAS TRUE
FONT arial
MAXSIZE 256
MINSIZE 4
SIZE 10
TYPE TRUETYPE
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS ON
END
QUERYMAP
COLOR 255 255 0
SIZE 300 300
STATUS ON
STYLE HILITE
END
REFERENCE
COLOR -1 -1 -1
EXTENT 3.35726e+06 5.68232e+06 3.42886e+06 5.75403e+06
IMAGE "D:\ms4w\Apache\images\reference.png"
OUTLINECOLOR 255 0 0
SIZE 150 150
STATUS ON
MARKER 0
MARKERSIZE 0
MINBOXSIZE 3
MAXBOXSIZE 0
END
SCALEBAR
BACKGROUNDCOLOR 255 255 255
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
OUTLINECOLOR 0 0 0
POSITION LL
SIZE 300 5
STATUS ON
STYLE 0
UNITS METERS
END
WEB
EMPTY "D:\ms4w\Apache\html\emptytemplate.html"
FOOTER "D:\ms4w\Apache\html\footer.html"
HEADER "D:\ms4w\Apache\html\header.html"
IMAGEPATH "D:\ms4w\Apache\tmp"
IMAGEURL "D:\ms4w\Apache\tmp"
LOG "D:\ms4w\Apache\logs"
METADATA
"wms_onlineresource" "http://10.224.160.25:8080/cgi-bin/mapserv.exe?map=D:\ms4w\Apache\cgi-bin\mapfile.map&"
"ows_schemas_location" "http://10.224.160.25/cgi-bin"
"wms_title" "Rasterdaten autark"
"wms_enable_request" "*"
"ows_enable_request" "*"
END
QUERYFORMAT text/html
TEMPLATE "D:\ms4w\Apache\html\lkee.html"
END
LAYER
NAME "dtk10far"
OFFSITE 255 255 255
SIZEUNITS PIXELS
STATUS ON
TILEINDEX "D:\Disma5\geodaten\TKs\TKs2009\DTK10\DTK10FAR\25833\dtk10far.shp"
TILEITEM "location"
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE RASTER
UNITS METERS
CLASS
NAME "dtk10far"
METADATA
END
STYLE
END
END
END
END
This file is a modified copy of an older mapfile that was used on a linux system and worked well as WMS server.
When I send the request
http://disma:8080/cgi-bin/mapserv.exe?map=D:\ms4w\Apache\cgi-bin\mapfile.map&SERVICE=WMS&REQUEST=Getmap&VERSION=1.1.1&LAYERS=dtk10far&SRS=EPSG:25833&BBOX=360575,5688787,425797,5752560&FORMAT=PNG&WIDTH=600&HEIGHT=600
I get a map image as I expected. So far so good.
But I want to use Mapserver as Mapserver for use in the intranet. It will be requested by a single client on the same host that has a WMS interface. Now, when I send a GetCapabilities request
http://disma:8080/cgi-bin/mapserv.exe?map=D:\ms4w\Apache\cgi-bin\mapfile.map&request=GetCapabilities
I simply get nothing, a white page, no error message, no entry in error.log
I wonder if the somewhat ugly wms_onlineresource is responsible ("wms_onlineresource" "http://10.224.160.25:8080/cgi-bin/mapserv.exe?map=D:\ms4w\Apache\cgi-bin\mapfile.map&"). But when I comment this line out, the result is unchanged.
What do I have to change to make Mapserver work as a WMS server?
Sincerely
Erwin
Erwin Bimüller
GIS-Verantwortlicher im Landkreis Elbe-Elster
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160729/bafd9068/attachment.html>
