[mapserver-users] Multiple styles in a MapServer WMS Service
mmohr
marcus.mohr at geobasis-bb.de
Tue Jun 7 02:11:24 PDT 2016
Hello Simon, here is an example that worked for me:
LAYER
METADATA
"wms_title" "Test title"
"wms_style" "first_style"
"wms_style_default_legendurl_width" "226"
"wms_style_default_legendurl_height" "431"
"wms_style_default_legendurl_format" "image/png"
"wms_style_default_legendurl_href"
"http://eidc.ceh.ac.uk/administration-folder/tools/wms/987544e0-22d8-11e4-8c21-0800200c9a66/legends/LCM2007_DomTar.png"
"wms_style" "second_style"
"wms_style_inspire_common:DEFAULT_legendurl_width" "226"
"wms_style_inspire_common:DEFAULT_legendurl_height" "431"
"wms_style_inspire_common:DEFAULT_legendurl_format" "image/png"
"wms_style_inspire_common:DEFAULT_legendurl_href"
END
NAME "test_layer"
CLASSGROUP "first_style"
TYPE POLYGON
INCLUDE "test_dbconnection.include"
DATA "the_geom FROM test using srid=25833"
CLASSITEM "test"
STATUS ON
### FIRST Style ###
CLASS
GROUP "first_style"
NAME "Name 1"
KEYIMAGE "LCM2007_DomTar.png"
EXPRESSION "poly_1"
STYLE
COLOR 255 137 104
END
END
### SECOND STYLE ###
CLASS
GROUP "second_style"
NAME "Name 2"
EXPRESSION "poly_2"
STYLE
COLOR 243 198 131
END
END
END
This layer has three styles now: default, first_style and second_style (you
can easily check that in your GIS). But only the last both styles will
propably appear in the section of your layer capabilities. The default
stylename of your root-element is also "default" (you can change this with
"wms_style_name" in the WEB.METADATA section) and style declarations are
always inherited by child Layers! Inherited styles only appear once (at the
parent element).
If you didn't set the "wms_style_name" in the WEB.METADATA section it's not
a bug if your "default" style doesn't appear in the layer caps. You can get
it anyway.
Please have a look at the OGC WMS 1.3 Specification, Point 7.2.4.6.5
(http://portal.opengeospatial.org/files/?artifact_id=14416) to get more
Information about this behaviour.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Multiple-styles-in-a-MapServer-WMS-Service-tp5269071p5270322.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
