[mapserver-users] Rendering of adjacent dashed lines
thomas bonfort
thomas.bonfort at gmail.com
Fri Jun 17 07:20:51 PDT 2016
Hi Stefan,
Unfortunately no. When I said "impossible" I meant it in the general
case, not for MapServer specifically.
Regards,
thomas
On 17 June 2016 at 16:17, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> Hi Thomas
> Would it be possible to fund such a feature?
> Stefan
> Sent from my iPhone
>> On 17 Jun 2016, at 16:05, thomas bonfort <thomas.bonfort at gmail.com> wrote:
>> Stefan,
>> There is no trick/workaround for this aside from preprocessing your
>> data to merge adjacent lines into one. In the general case what you
>> are aiming for is impossible as your adjacent lines will have
>> different lengths but will be using a fixed length dash pattern.
>> thomas
>>> On 17 June 2016 at 12:38, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
>>> Hi
>>> I'm trying to render some lines with a pattern. This works and looks great as long as the lines are not adjacent. When the lines share a common border the dashed lines may look ugly since one dashed line is rendered on top of the other rendered dashed line. I tried to add a white solid line under the dashed line:
>>> CLASS
>>> STYLE
>>> COLOR 255 255 255
>>> WIDTH 2
>>> LINECAP BUTT
>>> END
>>> STYLE
>>> COLOR 0 0 0
>>> WIDTH 2
>>> LINECAP BUTT
>>> PATTERN 20 4 2 4 2 4 END
>>> END
>>> END
>>> But the behaviour is still the same. Is there a trick/workaround for this? I'm using MapServer 7.0.1.
>>> Best regards
>>> Stefan Ziegler
>>> Freundliche Grüsse
>>> Stefan Ziegler
>>> Kantonsgeometer / Leiter Amt für Geoinformation
>>> Rötistrasse 4
>>> 4500 Solothurn
>>> Telefon +41 32 627 75 96
>>> Telefax +41 32 627 75 98
>>> stefan.ziegler at bd.so.ch
>>> http://www.so.ch
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
