[mapserver-users] Rendering of adjacent dashed lines
thomas bonfort
thomas.bonfort at gmail.com
Fri Jun 17 07:41:14 PDT 2016
Can you post a screenshot?
On 17 June 2016 at 16:27, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> Then I wasn't propably clear about the problem. I can get the desired effect in QGIS. The line symbol is a combination of two line symbols. One is dashed, one is solid.
> Regards
> Stefan
> Sent from my iPhone
>> On 17 Jun 2016, at 16:20, thomas bonfort <thomas.bonfort at gmail.com> wrote:
>> Hi Stefan,
>> Unfortunately no. When I said "impossible" I meant it in the general
>> case, not for MapServer specifically.
>> Regards,
>> thomas
>>> On 17 June 2016 at 16:17, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
>>> Hi Thomas
>>> Would it be possible to fund such a feature?
>>> Stefan
>>> Sent from my iPhone
>>>> On 17 Jun 2016, at 16:05, thomas bonfort <thomas.bonfort at gmail.com> wrote:
>>>> Stefan,
>>>> There is no trick/workaround for this aside from preprocessing your
>>>> data to merge adjacent lines into one. In the general case what you
>>>> are aiming for is impossible as your adjacent lines will have
>>>> different lengths but will be using a fixed length dash pattern.
>>>> thomas
>>>>> On 17 June 2016 at 12:38, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
>>>>> Hi
>>>>> I'm trying to render some lines with a pattern. This works and looks great as long as the lines are not adjacent. When the lines share a common border the dashed lines may look ugly since one dashed line is rendered on top of the other rendered dashed line. I tried to add a white solid line under the dashed line:
>>>>> CLASS
>>>>> STYLE
>>>>> COLOR 255 255 255
>>>>> WIDTH 2
>>>>> LINECAP BUTT
>>>>> END
>>>>> STYLE
>>>>> COLOR 0 0 0
>>>>> WIDTH 2
>>>>> LINECAP BUTT
>>>>> PATTERN 20 4 2 4 2 4 END
>>>>> END
>>>>> END
>>>>> But the behaviour is still the same. Is there a trick/workaround for this? I'm using MapServer 7.0.1.
>>>>> Best regards
>>>>> Stefan Ziegler
>>>>> Freundliche Grüsse
>>>>> Stefan Ziegler
>>>>> Kantonsgeometer / Leiter Amt für Geoinformation
>>>>> Rötistrasse 4
>>>>> 4500 Solothurn
>>>>> Telefon +41 32 627 75 96
>>>>> Telefax +41 32 627 75 98
>>>>> stefan.ziegler at bd.so.ch
>>>>> http://www.so.ch
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
