[mapserver-users] Remote MapFile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Mar 21 04:32:03 PDT 2016
Hi Marco,
As Thomas mentioned, you'll have to use a different way. If you're
using MS4W you can use PHP MapScript to pass your mapfile to your PHP
script, and then use CURL commands (already included as a PHP extension
in MS4W) to download the remote mapfile locally to your server.
Something like:
http://localhost/myapp/index.php?map=http://remotemachine/mymap.map
There are good examples of how to use CURL for this at:
http://php.net/manual/en/ref.curl.php
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-03-21 7:50 AM, Marco Afonso wrote:
> Hi all,
> It is possible to get a remote mapfile instead from a local path in the
> cgi-variable?
> For example, instead of:
> http://localhost:8081/cgi-bin/mapserv.exe?map=/local/path/mymap.map
> Something like:
> http://localhost:8081/cgi-bin/mapserv.exe?map=http://remotemachine/mymap.map
> Thank you!
> Best Regards,
> Marco Afonso
> http://goo.gl/ZDtQjm
More information about the MapServer-users
