[mapserver-users] Mapserver - connection to MSSQL
Seth G
geographika at gmail.com
Wed May 11 00:14:49 PDT 2016
The error message indicates there is a problem with your connection string:
'MSSQL:driver=FreeTDS;server=db-agribase-p.asurequality.com' does not
contain the 'database' portion
If the database part is not missing, maybe there is a missing
semi-colon, or special character ending the database connection string?
Regards,
Seth
On 10/05/2016 23:54, Robert Sanson wrote:
> Hi
> I am trying to create a Mapserver (v 6.4.1 on Ubuntu) layer based on a
> MSSQL table with native geometry.
> I have tested the connection via ogrinfo (based on gdal v 2.0.2) and
> it works:
> ogrinfo -sql "select * from par_table where par_no = 6777887"
> "MSSQL:driver=FreeTDS;server=myserver,1433;uid=xx;pwd=xxx;database=mydb;trusted_connection=no;tables=par_table(geom)"
> This is my layer section:
> LAYER
> NAME par_direct
> GROUP "CRS"
> STATUS ON
> CONNECTIONTYPE ogr
> CONNECTION
> FILTER "WHERE date_dropped is null"
> TYPE POLYGON
> PROCESSING 'CLOSE_CONNECTION=DEFER'
> MAXSCALE 275000
> CLASS
> STYLE
> WIDTH 0.25
> OUTLINECOLOR 0 0 255
> END
> END
> METADATA
> "ows_title" "par_direct"
> "wms_group_title" "CRS"
> "wms_exceptions_format" "application/vnd.ogc.se_xml"
> "wms_abstract" "This is the LINZ parcel layer in NZTM"
> "wms_keywordlist" "LINZ,CRS"
> "wms_extent" "1114412.940 4793178.168 2089186.204 6190213.601"
> "gml_include_items" "all"
> "gml_exclude_items" ""
> "ows_include_items" "all"
> "ows_exclude_items" ""
> END
> END
> When I try a WMS getmap call I get this error message:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'par_direct'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
> `par_direct'.
> does not contain the 'database' portion
> </ServiceException>
> </ServiceExceptionReport>
> Any clues?
> Many thanks,
> Robert L. Sanson
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160511/d49ae493/attachment.html>
