[mapserver-users] Mapserver - connection to MSSQL
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed May 11 00:28:16 PDT 2016
The connection string in the mapfile does look perfect but something that happens for me is that if I copy and paste text the copy may contain invisible characters which make troubles. I would rewrite the CONNECTION again by hand from keyboard and try if it helps.
-Jukka Rahkonen-
Seth G wrote:
The error message indicates there is a problem with your connection string:
'MSSQL:driver=FreeTDS;server=db-agribase-p.asurequality.com' does not contain the 'database' portion
If the database part is not missing, maybe there is a missing semi-colon, or special character ending the database connection string?
Regards,
Seth
On 10/05/2016 23:54, Robert Sanson wrote:
Hi
I am trying to create a Mapserver (v 6.4.1 on Ubuntu) layer based on a MSSQL table with native geometry.
I have tested the connection via ogrinfo (based on gdal v 2.0.2) and it works:
ogrinfo -sql "select * from par_table where par_no = 6777887" "MSSQL:driver=FreeTDS;server=myserver,1433;uid=xx;pwd=xxx;database=mydb;trusted_connection=no;tables=par_table(geom)"
This is my layer section:
LAYER
NAME par_direct
GROUP "CRS"
STATUS ON
CONNECTIONTYPE ogr
CONNECTION "MSSQL:driver=FreeTDS;server=myserver,1433;uid=xx;pwd=xxx;database=mydb;trusted_connection=no;tables=par_table(geom)"
FILTER "WHERE date_dropped is null"
TYPE POLYGON
PROCESSING 'CLOSE_CONNECTION=DEFER'
MAXSCALE 275000
CLASS
STYLE
WIDTH 0.25
OUTLINECOLOR 0 0 255
END
END
METADATA
"ows_title" "par_direct"
"wms_group_title" "CRS"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
"wms_abstract" "This is the LINZ parcel layer in NZTM"
"wms_keywordlist" "LINZ,CRS"
"wms_extent" "1114412.940 4793178.168 2089186.204 6190213.601"
"gml_include_items" "all"
"gml_exclude_items" ""
"ows_include_items" "all"
"ows_exclude_items" ""
END
END
When I try a WMS getmap call I get this error message:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd"<http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd>>
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named 'par_direct'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `par_direct'.
</ServiceException>
</ServiceExceptionReport>
Any clues?
Many thanks,
Robert L. Sanson
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160511/f5ffad90/attachment-0001.html>
