[mapserver-users] Get styled .map file using sld?
Ashutosh Sharma
ashuandindia at hotmail.com
Thu May 12 06:25:56 PDT 2016
Hi All,
I want to know that is there any mechanism by which I can embed SLD based styling in a .map file.
I believe some mechanism must be there because when I pass SLD file path in WMS request, then in logs I got a message
"Map file after SLD was applied /tmp/57347d6a_9e9_b1._sld.map[Thu May 12 18:26:10 2016].813240 msDrawMap(): rendering using outputformat named jpeg (AGG/JPEG)"
This "/tmp/57347d6a_9e9_b1._sld.map" map file has styles generated using the passed sld file. I have tested this file and this is exactly what I wanted.
Is there any way (some api call or converter) to generated a styled .map file using sld without using the above hack ?
Ashutosh Sharma
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160512/f41e578e/attachment.html>
