[mapserver-users] Question about WMS Dimension and Cluster
Frode Wiseth Jørgensen
frodewj at gmail.com
Thu Nov 17 03:57:28 PST 2016
Hi
When combining Cluster and WMS dimension it seems like the Cluster is
ignored.
This leeds to for instance that attribute "Cluster_FeatureCount" is missing
so using it on SIZE and LABELS won't work and there is no clustering of
objects.
Is Clustering supposed to work when using WMS Dimension?
*Sample of mapfile etc:*
- GetMap request with dimension filter: &dim_mainmissiontype=Brann
- gives non clustered map and if for instance Cluster_FeatureCount is
used, an error is thrown
- The same GetMap request without dimension filter
- gives a image with clustered objects
Example mapfile:
LAYER
TYPE point
METADATA
"WMS_TITLE" "Fire rescue missions2"
"GML_INCLUDE_ITEMS" "oppdragid,mainmissiontype"
"WMS_INCLUDE_ITEMS" "oppdragid,mainmissiontype"
"WMS_MAINMISSIONTYPE_ITEM" "mainmissiontype"
"WMS_MAINMISSIONTYPE_EXTENT" "Andre oppdrag,Brann,Brannhindrende
tiltak,Ulykke"
"WMS_MAINMISSIONTYPE_UNITS" ""
"WMS_MAINMISSIONTYPE_DEFAULT" ""
"WMS_DIMENSIONLIST" "mainmissiontype"
END
CONNECTION "user=xx password=xx dbname=xx host=localhost port=5433"
CONNECTIONTYPE postgis
DATA "wkb_geometry FROM (SELECT oppdragid, mainmissiontype,
wkb_geometry FROM firerescuemissions) AS MYTABLE USING UNIQUE oppdragid
USING SRID=4326"
EXTENT -9223372036.854776 0 31.118456919 9223372036.854776
NAME "layer_x"
PROCESSING "CLOSE_CONNECTION=DEFER"
PROCESSING "CLUSTER_GET_ALL_SHAPES=ON"
PROCESSING "ITEMS=oppdragid,mainmissiontype"
PROJECTION "init=epsg:4326" END
CLASS
NAME "class"
STYLE
ANGLE auto
COLOR 255 127 0
LINECAP round
LINEJOIN round
MAXSIZE 30
MINSIZE 10
OUTLINECOLOR 0 0 0
SIZE [Cluster_FeatureCount]
SYMBOL "circle"
WIDTH 1
END
END
CLUSTER
MAXDISTANCE 40
REGION "ellipse"
END
END
Example error message:
- Error using Mapserver 7.0.1 and 7.0.2:
- msDrawMap(): Image handling error. Failed to draw layer named
'layer_x'.msPostGISLayerWhichShapes(): Query error. Error
executing query.
Check server logs
- Error using Mapserver 6.4.0:
executing query:
ERROR: column "Cluster:FeatureCount" does not exist
LINE 1: select
"Cluster:FeatureCount",encode(ST_AsBinary(ST_Force_2D...
Running Mapserver on Windows, using binary from gisinterals.com.
Thanks
FrodeWJ
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161117/13503424/attachment.html>
