[mapserver-users] Refreshing AWS credentials for the /vsis3/ driver
Even Rouault
even.rouault at spatialys.com
Thu Nov 24 08:12:57 PST 2016
> That's what I suspected. The IFD are not placed at the beginning of the
> file, but rather rewritten after each "data section".
> Which libtiff version is used in your GDAL build: internal libtiff or
> system libtiff (if so, which version)? But I wouldn't surprise that the
> issue exists with any libtiff version because of what I mentionned with
> jpeg compression. That might probably be fixable (likely with some
> headaches)
Follow up : I've just committed a fix in GDAL trunk so that -co
COPY_SRC_OVERVIEWS=YES -co COMPRESS=JPEG produces those "cloud optimized
geotiffs" with the IFD first in the file. Similarly to other compression schemes
or uncompressed images.
Even
http://www.spatialys.com
