[mapserver-users] MapServer IIS7
Vogt, Robert (RCIS)
Robert.Vogt at rcis.com
Thu Oct 13 08:10:39 PDT 2016
I have and it also works in mapserver but only while using Apache as the server.
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Thursday, October 13, 2016 10:31 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MapServer IIS7
Have you tried to connect to the sql server outside of mapserver using the same credentials? ie: make sure the the mapserver user is a valid user to do the connection with.
-Steve W
On 10/13/2016 10:18 AM, Vogt, Robert (RCIS) wrote:
> This is the full error...
> 502 - Web server received an invalid response while acting as a gateway or proxy server.
> There is a problem with the page you are looking for, and it cannot be displayed. When the Web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from the content server.
> On Behalf Of Vogt, Robert (RCIS)
> Sent: Thursday, October 13, 2016 10:12 AM
> Subject: [mapserver-users] MapServer IIS7
> Good morning,
> I originally set up MapServer with WS4W and Apache server...I now have a requirement to put this on the same domain as our application which runs in IIS7.
> I have created the site and pointed my application at it and the results are mixed...
> Map files that are pointed at lizardtech for their source are working but map files that are pointed at SQL for their source are giving a 502(bad gateway) error.
> All map files worked when served through Apache, has anyone run into this or know what I should look at to fix it?
> Your help is greatly appreciated!!
> ******** Map File ***************************
> MAP
> IMAGETYPE PNG24
> CONFIG "PROJ_LIB" "E:/RCIS/Web/MapServerDlls/projlib"
> SIZE 256 256
> FONTSET "E:/RCIS/Web/MapServerDlls/content/fontset.txt"
> IMAGECOLOR 255 255 255
> TRANSPARENT ON
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "wms_title" "sections"
> "wms_enable_request" "*"
> END
> END
> LAYER
> NAME "States"
> TYPE POLYGON
> STATUS ON
> LABELCACHE ON
> PROCESSING 'LABEL_NO_CLIP=1'
> CONNECTIONTYPE PLUGIN
> PLUGIN "msplugin_mssql2008.dll"
> CONNECTION "OurConnectionString"
> DATA "shape(geography),ST_NAME_MC from NATIONALDB.sde.STATES USING INDEX STATES_SIDX USING UNIQUE STATES_ID USING SRID=4269"
> LABELITEM "ST_NAME_MC"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CLASS
> STYLE
> OUTLINECOLOR 000 153 000
> WIDTH 3
> END
> LABEL
> COLOR 000 153 000
> TYPE TRUETYPE
> FONT Arial
> SIZE 12
> ANTIALIAS FALSE
> POSITION AUTO
> PARTIALS FALSE
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> END
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
