[mapserver-users] KML output 6.4.2
Moisan, Yves (EC)
yves.moisan at canada.ca
Tue Oct 18 13:45:31 PDT 2016
Hi All,
Haven't been here in a while ... I'm striving to find out how to either query MS or run a command to generate a KML document ready to be ingested by Google Earth. I've seen the documentation mentioning "Output can then be generated using MapServer cgi (example mode=map) or through a WMS request." [1] and I understand the capability has been there since 6.0, but I can't get around to obtaining a KML document that has <NetworkLink> elements pointing to the GetMap requests of particular layers. I do get KML documents (with FORMAT=kml), but they miss a <NetworkLink> element in the <Folder> element corresponding to a layer from which GE could fetch an image :
<Folder>
<name>MyName</name>
<visibility>1</visibility>
<styleUrl>#LayerFolder_check</styleUrl>
<!-- NetworkLink> MISSING </NetworkLink -->
</Folder>
Examples or pointers anyone ?
TIA,
Yves
[1] http://mapserver.org/output/kml_output.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161018/c1daaf76/attachment.html>
