[mapserver-users] KML output 6.4.2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 18 15:00:24 PDT 2016
Hi Yves!
Not sure if this helps, but...I remember testing KMZ output through WMS
(in 2011), and I had found an issue with the output coordinates and had
filed a ticket: https://github.com/mapserver/mapserver/issues/3928 Note
that I just now dug up that old sample mapfile and data and added the
working link at the bottom of that old ticket.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-10-18 5:45 PM, Moisan, Yves (EC) wrote:
> Hi All,
> Haven’t been here in a while … I’m striving to find out how to either
> query MS or run a command to generate a KML document ready to be
> ingested by Google Earth. I’ve seen the documentation mentioning
> “Output can then be generated using MapServer cgi (example mode=map) or
> through a WMS request.” [1] and I understand the capability has been
> there since 6.0, but I can’t get around to obtaining a KML document that
> has <NetworkLink> elements pointing to the GetMap requests of particular
> layers. I do get KML documents (with FORMAT=kml), but they miss a
> <NetworkLink> element in the <Folder> element corresponding to a layer
> from which GE could fetch an image :
> <Folder>
> <name>MyName</name>
> <visibility>1</visibility>
> <styleUrl>#LayerFolder_check</styleUrl>
> <!-- NetworkLink> MISSING </NetworkLink -->
> </Folder>
> Examples or pointers anyone ?
> TIA,
> Yves
> [1] http://mapserver.org/output/kml_output.html
