[mapserver-users] Finding (and modifying?) status codes of mapserver responses
deduikertjes
deduikertjes at xs4all.nl
Wed Oct 19 09:08:47 PDT 2016
Thomas,
Thank you.
Interesting remark you make on the WMS-spec. Never thought of that.
You say that I can add a config option to return something other than
200. I suppose by that you mean that such a config option does not
exits, but that I can hack it in?
Can you please elaborate a bit on how non 200 status codes on service
exception reports could break a client. No map is no map?
Marco
On 19-10-16 14:50, thomas bonfort wrote:
> Marco,
> It's the WMS spec itself that requires 200 response codes. You can
> hack the code or even add a configuration option to return something
> other than 200, but you'll risk breaking your clients. Also note that
> checking for specific text is not going to work all the time, as the
> client can request an "inimage" exception text, i.e. returned as
> pixels in a png image.
> thomas
> On Wed, Oct 19, 2016 at 9:03 AM deduikertjes <DeDuikertjes at xs4all.nl
> <mailto:DeDuikertjes at xs4all.nl>> wrote:
> Finding and modifying status codes
> I'd like to find out (and maybe modify) the HTML status codes
> mapserver
> attaches to a WMS service exception report.
> I deploy mapserver behind Nginx with supervisord as a fastcgi
> provider and
> process manager. Nginx does caching of responses on getmap requests.
> As I don't want Service Exception reports to be cached I've added a
> directive to the Nginx config not to cache error documents containing
> 'serviceException'.
> This is not working properly, I think because nginx only regards a
> response
> as an error when a non-200 status code is attached.
> So I'm trying to find the status codes mapserver attaches to a
> response.
> If I do from command line mapserv7
> QUERY_STRING="map=my.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&....(rest
> of valid wms request)" I see the headers (and the png) when te
> request leads
> to a response containing a map.
> If I do the same with a request that generates an service
> exception report I
> get back error messages instead of the response I see in my browser.
> So, how to find out the headers of the response before it goes trough
> supervisord an nginx?
> Or does anyone know what status code the header contains?
> And the million dollar question: can we stick a 500 status code
> header on
> the response if it's not there?
> Any help greatly appreciated, MArco
> http://osgeo-org.1560.x6.nabble.com/Finding-and-modifying-status-codes-of-mapserver-responses-tp5291371.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161019/34a50962/attachment.htm>
More information about the MapServer-users
