[mapserver-users] styling point shapefile for wms
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Apr 14 09:13:02 PDT 2017
Hi Derek,
Since your request is using WMS 1.3.0, the issue could be specifying
long/lat vs lat/long in your CRS parameter of the WMS GetMap request
(see example requests at
http://mapserver.org/ogc/wms_server.html#coordinate-systems-and-axis-orientation).
I would also check the GetCapabilities response for any warnings.
Also, another option for testing your mapfile styling instead of your
first link (CGI method) is to use the shp2img commandline utlity, that
comes ready for your use in MS4W as well (see
http://mapserver.org/utilities/shp2img.html).
Happy mapserving :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-04-13 10:29 PM, jmorgan3 wrote:
> Hello,
> I am attempting to set up a basic MapServer environment and finding
> myself such at what I think is a styling through WMS issue. I am finding
> if I call up a WMS via the following URL I get the expected results
> http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wq/wq.map&layer=wq_stations&mode=map
> However, if I call the same WMS using
> http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wq/wq.map&SERVICE=WMS&map=/ms4w/apps/wq/wq.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=wq_stations&CRS=EPSG:4326&BBOX=-87.6,30.00,-87.26,31.00&STYLES=&WIDTH=600&HEIGHT=600&FORMAT=image/png
> I get a blank page. Perhaps in the first URL I am not actually using
> WMS, but I am thinking the issue is more to do with how I setup or
> incorrectly my STYLE. Here is my map file for reference:
> # Start of map file
> MAP
> NAME WQ
> STATUS ON
> SIZE 600 600
> EXTENT -87.6 30.00 -87.26 31.00
> #EXTENT -87.60 28.67 -82.65 31.07 # [minx] [miny] [maxx] [maxy]
> IMAGETYPE PNG
> CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
> DEBUG 5
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> # change the next two lines to match your setup
> IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> WMS_TITLE "WQ Demo"
> WMS_ABSTRACT "This is WQ Demo"
> WMS_ENABLE_REQUEST "*"
> WMS_ACCESSCONSTRAINTS "none"
> # change this value to match your setup
> WMS_ONLINERESOURCE
> "http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wq/wq.map"
> WMS_SRS "EPSG:4326"
> END
> END
> #Circle symbol
> #Ref:
> http://osgeo-org.1560.x6.nabble.com/Can-t-draw-points-from-shapefile-td5070300.html
> SYMBOL
> NAME 'CIRCLE'
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> # Start of layer definitions
> LAYER
> NAME "wq_stations"
> DATA 'data/ewqma_stations4326.shp'
> STATUS ON
> TYPE POINT
> CLASS
> STYLE
> SYMBOL 'CIRCLE'
> COLOR 255 1 1
> END
> END # CLASS
> END # LAYER
> END # LAYER
> END # Map File
> Any pointers on what I am doing or interpreting incorrectly would be
> greatly appreciated.
> Thanks,
> Derek
