[mapserver-users] geotiff 48bit with mapserver 7 wms
David F.
david at impstyle.com
Fri Apr 14 15:56:09 PDT 2017
I did not reply after my latest test, sorry.
I tried all tiff IMAGEMODE for my data set. None gave me 16 bit at the gis
client.
As far as I understand gtiff is 8 bit.
The only IMAGEMODE for integer is signed INT16 , which is unfortunately the
only supported integer data type. For RGB data unsigned integer is the only
integer data type that makes sense. Just if i change the IMAGEMODE to
FLOAT32 mapserver will serve more than 8 bit per band.
I think i will give gdal and float32 bit a try nevertheless it will double
the image size.
Maybe someone else has an idea.
On April 14, 2017 1:43:09 PM Stephen Woodbridge <woodbri at swoodbridge.com>
wrote:
> http://mapserver.org/mapfile/outputformat.html
> Why not serve them a GTiff format for qgis?
> You can define multiple output formats in the mapfile, and let the
> browser use the 8bit png and have qgis request images in gtiff format.
> -Steve
> On 4/13/2017 11:03 AM, David wrote:
>> Hi Steve,
>> thank you very much for your help. The Mapserver is serving the tiles
>> with the correct RGB values now. The problem is, that it is serving 8
>> bit per band and not 16 bit.
>> I need the 16bit because i want to use the wms as a base layer for some
>> further processing with qgis or another gis client. So no problem
>> regarding browsers for me.
>> I will take a look and change the data type to float32 for the tiff
>> files. At least this is an supported OUTPUTFORMAT for mapserver.
>> Any suggestions on this matter are highly appreciated.
>> Cheers,
>> David
>> ------ Original Message ------
>> From: mapserver-users-request at lists.osgeo.org
>> To: mapserver-users at lists.osgeo.org
>> Sent: 4/12/2017 4:00:02 PM
>> Subject: mapserver-users Digest, Vol 111, Issue 5
>>> Send mapserver-users mailing list submissions to
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>> mapserver-users-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of mapserver-users digest..."
>>> Today's Topics:
>>> 1. geotiff 48bit with mapserver 7 wms (David)
>>> 2. Re: geotiff 48bit with mapserver 7 wms (Stephen Woodbridge)
>>> Message: 1
>>> Date: Wed, 12 Apr 2017 00:22:12 +0000
>>> From: David <david at impstyle.com>
>>> Subject: [mapserver-users] geotiff 48bit with mapserver 7 wms
>>> Message-ID: <em5ce0e1b3-00b1-463e-8ad8-90100518d131 at laptop-dfriedrich>
>>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>> Hi there,
>>> iam having some trouble to serve 48 bit geotiff images with a mapserver
>>> 7 wms. I created to layers for speed purposes with scale limiters. The
>>> lowres layer is served well and looks good, it is 24bit geotiff
>>> data(8bit per channel). But if the layer changes to the highres, 48bit
>>> geotiff data(16bit per channel), the data is shown wrong.
>>> I searched for some hints regarding a similar issue but could not find
>>> something.
>>> This is a screenshot of the loaded highres layer. It does not matter if
>>> i load a bbox inside the browser, qgis or another wms client. The
>>> highres data looks always the same.
>>> image loaded from highres layer:
>>> http://imgur.com/a/B65cp
>>> the mapfile:
>>> https://pastebin.com/4G2DZErZ
>>> the gdalinfo for one 16bit 3-band tile:
>>> https://pastebin.com/kfS0BjmE
>>> Best Regards,
>>> David
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL:
>>> <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170412/2cded6b6/attachment-0001.html>
>>> Message: 2
>>> Date: Tue, 11 Apr 2017 21:25:01 -0400
>>> From: Stephen Woodbridge <woodbri at swoodbridge.com>
>>> Subject: Re: [mapserver-users] geotiff 48bit with mapserver 7 wms
>>> Message-ID: <a7bc734d-f7b9-32f3-5ce0-6a71aab4ead4 at swoodbridge.com>
>>> Content-Type: text/plain; charset=utf-8; format=flowed
>>> Read this:
>>> http://mapserver.org/input/raster.html
>>> You need to add to your highres layer
>>> PROCESSING "SCALE=AUTO"
>>> Or per band scaling. I done thing most browsers know what to do with 16
>>> bits per channel.
>>> -Steve W
>>> On 4/11/2017 8:22 PM, David wrote:
>>>> Hi there,
>>>> something.
>>>> the mapfile:
>>>> Best Regards,
>>>> David
>>>> _______________________________________________
>>> This email has been checked for viruses by Avast antivirus software.
>>> https://www.avast.com/antivirus
>>> Subject: Digest Footer
>>> End of mapserver-users Digest, Vol 111, Issue 5
