[mapserver-users] Scaling and sizeunits not matching up for hi-rez output.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Fri Feb 3 13:12:33 PST 2017
All,
apparently the MAXWIDTH setting is a way to override the limit in width display.
So for future, a chunk of my Mapfile that works to increase the width of the line at hi-rez:
TYPE POLYGON
SIZEUNITS feet
CLASS
STYLE
#COLOR 0 255 255
OUTLINECOLOR 0 150 255
WIDTH 200
MAXWIDTH 60 ## Pixels
## MAXWIDTH is a needed setting for scaling line widths
## beyond certain default (pixel) display limits.
END
END
(Thanks Jim.)
bobb
On Feb 2, 2017, at 4:15 PM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
I just ran into an interesting problem. I’m trying to output a large image (18000x12600 @ 300DPI or 42inX60in)
I’m scaling all the layers with SIZEUNITS set to FEET and have some line widths set at hundreds of feet for the width. It looks like there is a max size (pixels) that mapserver won’t draw a width past, but it looks like it’s variable, based on the size of the output image. The bigger the image out, the smaller the limit.
The line I’m measuring in the outputs is set to “WIDTH 300” in the mapfile.
BBOX=543000,132000,599500,177000 (units = feet)
56500 x 45000 (map units of feet.)
Output sizes:
24000x16400 = ~32 pixels (Should be about 80)
18000x12600 = ~35 pixels (should be about 60 I think)
12000x8400 = ~32 pixels (Should be about 40)
6000x4200 = ~20 pixels
3000x2100 = ~10 pixels
I think it’s being capped at 200 map units. I may have run into this same item a couple of year back when working on making some large labels with MapServer.
Anyone with any immediate thoughts?
bobb
"I've had a wonderful time, but this wasn't it."
- Groucho Marx
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
"Interesting - I use a Mac to help me design the next Cray."
- Seymoure Cray (1925-1996) when he was told that Apple Inc. had recently bought a Cray supercomputer to help them design the next Mac.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170203/9e14debf/attachment.html>
