[mapserver-users] Define an End-Time attribute in WMS Time
Andrea Peri
aperi2007 at gmail.com
Sun Feb 26 09:32:18 PST 2017
Hi Jeff.
I was understanding the wms_timeextend as defined in the annex C3 of OGC.
AFAIK it is the domains of availability for the values in the
time-field in all the dataset
But is always one only attribute. This is ok for spot events. Instead
when there is a dataset where every feature is a start-date and an
end-date of validity for every single feature of dataset.
As example:
the dataset of county boundaries. Sometime the county bounaries could
change so they have a startdate and an enddate.
So is need to define both: the end-date and the start-date using two
attribute fields.
I wrong to understand the wms_timeextend ?
Thx,
A.
2017-02-26 17:29 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> Hi Andrea,
> The possible WMS Time parameters for MapServer are documented at:
> http://mapserver.org/ogc/wms_time.html There is a "wms_timeextent"
> parameter that sets the possible start/end time range, but I am not sure if
> I am understanding your question fully.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2017-02-26 11:58 AM, Andrea Peri wrote:
>> Hi,
>> I need to define a WMS Time for using on an our dataset.
>> But I need colud define also a End-Time attribute. Because a single
>> feature has a
>> start-time validity and an end-time validity.
>> Searching for some workaround on internet, I see that this option
>> (start-time and end-time of validity for a feature) is allowed in
>> geoserver.
>> http://docs.geoserver.org/latest/en/user/data/webadmin/layers.html#data-webadmin-layers-edit-dimensions
>> So I hope it could be done also possible in mapserver.
>> Thx.
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
