[mapserver-users] mapserver, msProjectPoint() error
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 11 05:24:39 PDT 2017
Oh another tip is to set the EXTENT parameter at the LAYER level as well
(this is sometimes the magical solution for PostGIS/Oracle/database
layers served through WMS/WFS..).
Hope one of these tips helps you,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-07-11 9:08 AM, Jeff McKenna wrote:
> Hi Johnson,
> Welcome to the MapServer community.
> Regarding those errors, here are some rules that I always follow, that
> may help your case:
> - when serving through WMS/WFS etc, always make sure to remove all
> errors from a GetCapabilities response first (in your case, there might
> be warnings of missing metadata such as "wfs_srs").
> - try not to use a non-standard projection (EPSG:900913 was officially
> replaced by EPSG:3857 https://epsg.io/3857), you're just asking for
> possible trouble down the road if you do...
> - just to see if these errors are related to a projection, possibly
> setup a test case where your source data is in 4326, you serve the data
> through WFS in 4326, and your client-side application requests the data
> in 4326 (and see if those errors still exist)
> - possibly set the EXTENT values for the map object to the whole world:
> -180 -90 180 90
> - test your mapfile locally with the shp2img commandline utility
> (http://mapserver.org/utilities/shp2img.html)
> Other notes:
> I have seen odd projection errors like yours before, somehow being
> caused in a client-side javascript application requesting WMS/WFS
> layers. In my case I believe the maps were generated fine, so I might
> have 'lived' with those errors, not sure.
> -jeff
