[mapserver-users] Diagonal Point Fill
Seth G
sethg at geographika.co.uk
Wed May 17 15:31:43 PDT 2017
Hi list,
Is the recommended way to create a diagonal point fill such as
http://www.mapserver.org/_images/diagonal-area-symbol.png to use a
pixmap fill? This doesn't allow configuring size and color through STYLEs.
The page at http://www.mapserver.org/mapfile/symbology/construction.html
provides a vector symbol (coords below), but it is long/complex (with a
central circle and a quarter in each corner), and isn't easy to change
spacing between the points. The circle edges are also slightly jagged.
SYMBOL
NAME "diag_dots"
TYPE vector
FILLED true
POINTS
# Central circle:
0.7450 0.4500
0.7365 0.5147
0.7115 0.5750
0.6718 0.6268
0.6200 0.6665
0.5597 0.6915
0.4950 0.7000
0.4303 0.6915
0.3700 0.6665
0.3182 0.6268
0.2785 0.5750
0.2535 0.5147
0.2450 0.4500
0.2535 0.3853
0.2785 0.3250
0.3182 0.2732
0.3700 0.2335
0.4303 0.2085
0.4950 0.2000
0.5597 0.2085
0.6200 0.2335
0.6718 0.2732
0.7115 0.3250
0.7365 0.3853
0.7450 0.4500
-99 -99
0.25 0.0
0.2415 0.0647
0.2165 0.1250
0.1768 0.1768
0.1250 0.2165
0.0647 0.2415
0.0 0.25
0.0 0.0
0.25 0.0
-99 -99
1 0.25
0.9252 0.2415
0.8649 0.2165
0.8132 0.1768
0.7734 0.1250
0.7485 0.0647
0.74 0.0
1 0.0
1 0.25
-99 -99
0.74 1
0.7485 0.9252
0.7734 0.8649
0.8132 0.8132
0.8649 0.7734
0.9252 0.7485
1 0.74
1 1
0.74 1
-99 -99
0.0 0.74
0.0647 0.7485
0.1250 0.7734
0.1768 0.8132
0.2165 0.8649
0.2415 0.9252
0.25 1
0.0 1
0.0 0.74
END
END
Regards,
Seth
web: http://geographika.co.uk
twitter: @geographika
