[mapserver-users] WMS - Change color map of a DEM dynamically
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 30 17:14:43 PDT 2017
Here is a good explanation:
https://lists.osgeo.org/pipermail/gdal-dev/2014-May/039091.html
On 5/30/2017 8:09 PM, Stephen Woodbridge wrote:
> I don't use QGIS so maybe someone else has some idea how to do what you
> want with that. I think I might try something along these lines:
> Create a GDAL VRT file for each theme and add appropriate color tables
> for them. You might need to write a script to generate the color ramps
> as color table entries, but once you have them you should be good.
> The VRT files can all reference the same DEM.tif file so you are only
> create VRT file for the color tables.
> Then create appropriate layers in the mapfile each referencing one of
> the VRT files. Then the user can select the appropriate WMS layer from
> the mapfile dor the styling they want.
> -Steve W
> On 5/30/2017 7:56 PM, Eduardo Kanegae wrote:
>> Hi,
>> I'm running MapServer 7.0.5 with GDAL 2.2.0 (CentOS x64) and have a
>> 6Gb DEM tiff(float32) with overviews. Currently I set up a color ramp
>> in QGIS based on values/colors of some GRASS color tables such as
>> ETOPO2, SRTM and Terrain.
>> Then in mapfile I used a color ramp (colorrange, datarange, rangeitem)
>> coying colors and limit values from QGIS themes.
>> I'd like to let users to dynamically change the WMS raster output
>> using QGIS. Then, it could avoid to duplicating LAYERS declarations
>> such as "dem_srtmtheme", "dem_etopo2theme" and so on.
>> Or this (such as SLD) will be possible only for 8bit rasters and vectors?
>> thanks in advance.
>> Here's the dump(gdalinfo) of my raster file:
>> Driver: GTiff/GeoTIFF
>> Files: /myfile.tif
>> /myfile.tif.ovr
>> Size is 45369, 38050
>> Coordinate System is:
>> PROJCS["SIRGAS 2000 / UTM zone 23S",
>> GEOGCS["SIRGAS 2000",
>> DATUM["Sistema_de_Referencia_Geocentrico_para_las_AmericaS_2000",
>> SPHEROID["GRS 1980",6378137,298.257222101,
>> AUTHORITY["EPSG","7019"]],
>> TOWGS84[0,0,0,0,0,0,0],
>> AUTHORITY["EPSG","6674"]],
>> PRIMEM["Greenwich",0,
>> AUTHORITY["EPSG","8901"]],
>> UNIT["degree",0.0174532925199433,
>> AUTHORITY["EPSG","9122"]],
>> AUTHORITY["EPSG","4674"]],
>> PROJECTION["Transverse_Mercator"],
>> PARAMETER["latitude_of_origin",0],
>> PARAMETER["central_meridian",-45],
>> PARAMETER["scale_factor",0.9996],
>> PARAMETER["false_easting",500000],
>> PARAMETER["false_northing",10000000],
>> UNIT["metre",1,
>> AUTHORITY["EPSG","9001"]],
>> AXIS["Easting",EAST],
>> AXIS["Northing",NORTH],
>> AUTHORITY["EPSG","31983"]]
>> Origin = (268724.500000000000000,7485552.500000000000000)
>> Pixel Size = (1.000000000000000,-1.000000000000000)
>> Metadata:
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left ( 268724.500, 7485552.500) ( 47d15' 6.30"W, 22d43'17.44"S)
>> Lower Left ( 268724.500, 7447502.500) ( 47d15'26.74"W, 23d 3'53.89"S)
>> Upper Right ( 314093.500, 7485552.500) ( 46d48'36.78"W, 22d43'37.63"S)
>> Lower Right ( 314093.500, 7447502.500) ( 46d48'53.22"W, 23d 4'14.43"S)
>> Center ( 291409.000, 7466527.500) ( 47d 2' 0.78"W, 22d53'46.41"S)
>> Band 1 Block=45369x1 Type=Float32, ColorInterp=Gray
>> NoData Value=-32768
>> Overviews: 22685x19025, 11343x9513, 5672x4757, 2836x2379
>> Eduardo Patto Kanegae
>> http://www.webmapit.com.br | @webmapit
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
