[mapserver-users] Getting an empty MVT output for a point layer
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Aug 8 09:00:42 PDT 2018
We do not have your data for testing but please modify your mapfile a bit and make it to work with some public dataset, like Natural Earth populated places https://www.naturalearthdata.com/http//www.naturalearthdata.com/download/110m/cultural/ne_110m_populated_places.zip<https://www.naturalearthdata.com/http/www.naturalearthdata.com/download/110m/cultural/ne_110m_populated_places.zip>?
-Jukka Rahkonen.
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Caleb Lee
Lähetetty: 8. elokuuta 2018 17:47
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Getting an empty MVT output for a point layer
I am using MapServer 7.2.0 to generate mvt for two layers (one line layer and one point layer). I am able to generate mvt output for a line layer but is having problem with a point layer. The mvt output is kind of empty (just contains layer name and column names). I am getting correct geojson outputs for both layers using WFS.
Here is the URL that I use to get MVT output:
mapserv?map=D:\home\site\wwwroot\100k_3857_node.map&mode=tile&tilemode=gmap&tile=18+24+6&layers=nodes&map.imagetype=mvt
Here is the map file:
MAP
EXTENT -9036156 4707746 -8243569 5174793
CONFIG "PROJ_LIB" "D:\proj\SHARE"
NAME "TestMap"
WEB
METADATA
"ows_enable_request" "*"
END
END
PROJECTION
"init=epsg:3857"
END
OUTPUTFORMAT
NAME "mvt"
DRIVER MVT
FORMATOPTION "EDGE_BUFFER=20"
END
LAYER
NAME "nodes"
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION "Connection to SQL Server Spatial"
DATA "GeomCol from MyTable USING UNIQUE id USING SRID=3857"
CLASS
STYLE
COLOR 0 0 0
END
END
PROJECTION
"+init=epsg:3857"
END
METADATA
"wfs_title" "WFS service for Nodes"
"wfs_srs" "EPSG:3857 EPSG:4326"
"wfs_abstract" "WFS service for Nodes"
"wfs_enable_request" "*"
"gml_include_items" "all"
END
END
END
With almost an identical map file and an url (layer name and table name differ), I am getting a good mvt output for my line layer.
Any suggestions would be greatly appreciated.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180808/5e0591ba/attachment-0001.html>
