[mapserver-users] GetMap vs GetFeatureinfo sort
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Tue Aug 28 00:12:49 PDT 2018
hm, I would have expected the classes to be drawn in the same order as
in the mapfile.
You could try to use the label-section with geomtransform 'labelpoint'
[1], perhaps mapserver there takes care of the mapfile order...
Another option would be to use grouped layers, I guess you found this
already:
https://gis.stackexchange.com/questions/71152/mapserver-layer-classes-display-order
-> 2nd answer
Jörg
[1] https://mapserver.org/mapfile/label.html
[2] https://mapserver.org/mapfile/geomtransform.html
Am 27.08.2018 um 20:37 schrieb pe_lord:
> Thanks.
> Here more informations.
> I have 2 overlapping geometries.
> My class are based on a field ==> CLASSITEM "code_type" and appear in my
> mapfile in this order.
> CLASS
> NAME "Blue CLASS"
> EXPRESSION '1'
> STYLE
> SYMBOL "square"
> SIZE 8
> COLOR 53 68 150
> END
> END
> CLASS
> NAME "Red Class"
> EXPRESSION '4'
> STYLE
> SYMBOL "square"
> SIZE 8
> COLOR 188 34 115
> END
> END
> My data is stored in this order into PG, with this structure (id,
> code_type,geom):
> id1,4,geom
> id2,1,geom
> If I understand properly, my last geometrie (id2) is plotted on top of other
> classes. This is making sense.
> Otherwise, in the getfeatureinfo, the same order is kept, this a non-sense
> according to my classes's order.
> I would like to to present this data in a flipped order like, according to
> my classes's logic:
> id2,1
> id1,4
> I expect that the topmost feature returned in getfeatureinfo response
> correspond to the topmost feature drawn on map. I would like to have a
> constant response, independently from my template format (gml, html,
> json...)
> You will find an
> <http://osgeo-org.1560.x6.nabble.com/file/t378858/sl.png>
> Here what I tried without succes:
> - flip my mapfile's classes
> - sort my data based on my field (code_type). In this case, either I have
> the getmap sorted in the right order, or the getfeatureinfo. Both behaviors
> are impossible at the same time.
> Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
FOSS Academy Sommerschule 2018
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen erlernen!
https://www.foss-academy.com/kompaktkurse
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
