[mapserver-users] Map rendering correctly with shp2img but blank when using WMS
Seth G
sethg at geographika.co.uk
Mon Feb 12 15:32:29 PST 2018
Syntax looks fine to me.
Could there be an issue accessing the Mapfile using the web
service account?Can you run a profiler on the database to see if it is being hit at all?
The results of this would reduce the list of possible issues.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Mon, Feb 12, 2018, at 5:05 PM, Pablo Sanfilippo wrote:
> This is the command I'm using that renders fine:
> shp2img \ -m /maps/config.map \ -o /sources/testb.png \ -e -
> 118.41347694396971 33.919930516263086 -118.40274810791016
> 33.92787160756615 \ -s 500 500 \ -l mylayer \ -all_debug 5 \> And this WMS request renders a transparent image:
> http://localhost:8080/?map=/maps/config.map&SERVICE=WMS&VERSION=1.1.1%20&REQUEST=GetMap&LAYERS=mylayer&STYLES=&SRS=EPSG:4326&BBOX=-118.41347694396971,33.919930516263086,-118.40274810791016,33.92787160756615&WIDTH=500&HEIGHT=500&FORMAT=image/png>
> This is my mapfile:
> # A valid mapfile used for testing
> MAP
> NAME valid
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> # IMAGECOLOR 0 0 0
> TRANSPARENT ON
> WEB
> METADATA
> "wms_title" "Slingshot WMS Server"
> "wms_onlineresource" "http://localhost:8080/?map=config.map&"
> "wms_enable_request" "GetCapabilities GetMap GetFeatureInfo"
> "wms_srs" "EPSG:4326 EPSG:3857"
> END
> END
> LAYER
> NAME "myindex"
> STATUS ON
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "mypostgisconnection"
> DATA "geometry from (select i.geometry, i.id, '/sources/' ||
> i.path as location from images_image) as myindex using unique id"> CLASS
> STYLE
> OUTLINECOLOR 0 0 0
> COLOR 0 255 0
> WIDTH 1.0
> ANTIALIAS true
> END
> END
> END
> LAYER
> NAME "mylayer"
> STATUS ON
> TILEINDEX "myindex"
> TILEITEM "location"
> PROCESSING "SCALE=AUTO"
> TYPE RASTER
> PROJECTION
> AUTO
> END
> METADATA
> "wms_title" "My Imagery"
> END
> END
> END
> I'm using MapServer 7.0.1
> Thanks!
> _________________________________________________
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180213/1fdd74a3/attachment.html>
