[mapserver-users] WFS server setup with sqlite data
Ian Walberg
ian.walberg at airborne.aero
Wed May 16 15:26:32 PDT 2018
Folks,
We have a working WFS setup on our linux servers which has the sqlite database table as the value in the DATA field.
However when we run this on Windows we get no data returned.
In the logs there is a number of what appear to be warnings however it looks like no matching records were found.
msOGRFileNextShape: Rejecting feature (shapeid = 0, tileid=0) of incompatible type for this layer (feature wkbType 0, layer type 1)
msQueryByRect(): Search returned no results. No matching record(s) found.
Changing the DATA filed to be ‘select * from table’ works ok on windows.
Any help working out what the cause of the problem is appreciated.
Thanks, Ian
LAYER
NAME Cities_3x
#DEBUG 5
METADATA
"wfs_srs" "EPSG:4326"
"wfs_title" "Cities_3x"
"gml_featureid" "Name"
"gml_include_items" "all"
"wfs_enable_request" "*"
"wfs_encoding" "UTF-8"
"wfs_abstract" "Points"
"wfs_getfeature_formatlist" "geojson"
END
TYPE point
STATUS ON
CONNECTIONTYPE OGR
CONNECTION 'Cities.db'
DATA 'Cities_3x' – works in Linux
DATA ‘select * from Cities_3x’ -- required for Windows
PROJECTION
"init=epsg:4326"
END # PROJECTION
END # LAYER
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180516/3c09c504/attachment.html>
