[mapserver-users] Default GetCapabilities Version Not Working
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Thu May 17 11:41:51 PDT 2018
I tried it locally with 7.0.4 and it works as expected. I can switch between a default of 1.1.1 or 1.3.0 easily with that metadata element. I can’t create the exception you’re seeing with the metadata regardless of what I set it to – it defaults back to 1.3.0. I can create the exception via URL. Are you sure clients aren’t passing bad versions as opposed to no version?
--Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lime, Steve D (MNIT)
Sent: Thursday, May 17, 2018 1:32 PM
To: Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov>; mapserver-users <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Default GetCapabilities Version Not Working
Hi Matthew: Looking at the code MapServer 7.0 defaults to 1.3.0 already for GetCapabilties requests – you shouldn’t need that line. That said, it should work… --Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
Sent: Wednesday, May 16, 2018 4:22 PM
To: mapserver-users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [mapserver-users] Default GetCapabilities Version Not Working
All,
We are running MapServer version 7.0.1 and attempting to use the MAP > WEB > METADATA > wms_getcapabilities_version configuration value to support GetCapabilities requests that do not supply the VERSION parameter. Unfortunately, even if we do add this value to our mapserver configuration file, we continue to see the following service exception. Any suggestions?
msOWSParseVersionString(): OWS error. Invalid version (). Version must be in the format 'x.y' or 'x.y.z'
Here is our METADATA block:
WEB
METADATA
"wms_enable_request" "GetMap GetCapabilities"
"wms_title" "Some Text"
"wms_abstract" "Some Text"
"wms_onlineresource" "https://our_url?"
"wms_srs" "epsg:4326"
"wms_getcapabilities_version" "1.3.0"
"wms_connectiontimeout" "180"
END
END
Thanks,
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180517/da6ddb9b/attachment-0001.html>
