[mapserver-users] WFS server setup with sqlite data
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu May 17 06:49:10 PDT 2018
Hi Ian,
I have just now tested on Windows, using MS4W 3.2.7, using the
commandline utility shp2img.
I found an old sqlite database locally, but it caused me errors with
MapServer so I converted it to spatialite using an ogr2ogr command:
ogr2ogr -f SQLite myspatialite.sqlite original.sqlite -dsco
SPATIALITE=YES
And then I had no problems using the shp2img utility to produce a map
image (using both ways as you mentioned):
shp2img -m spatialite.map -o ttt.png -all_debug 3
Once I used ogr2ogr to convert to spatialite, I noticed many new table
changes, such as the table names changing to lowercase, which likely was
causing me troubles on my first tests on Windows.
I wonder what would happen in your case also, if you ran the ogr2ogr
command, which will update your sqlite database to a more recent version
(and likely automatically rename your 'Cities_3x' table name).
Note that MS4W (https://ms4w.com) nicely includes the sqlite3
commandline utility, so you can verify table names if you wish (or just
use ogrinfo command).
Hope that helps a little,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2018-05-16 7:26 PM, Ian Walberg wrote:
> Folks,
> We have a working WFS setup on our linux servers which has the sqlite
> database table as the value in the DATA field.
> However when we run this on Windows we get no data returned.
> In the logs there is a number of what appear to be warnings however it
> looks like no matching records were found.
> msOGRFileNextShape: Rejecting feature (shapeid = 0, tileid=0) of
> incompatible type for this layer (feature wkbType 0, layer type 1)
> msQueryByRect(): Search returned no results. No matching record(s) found.
> Changing the DATA filed to be ‘select * from table’ works ok on windows.
> Any help working out what the cause of the problem is appreciated.
> Thanks, Ian
> LAYER
> NAME Cities_3x
> #DEBUG 5
> METADATA
> "wfs_srs" "EPSG:4326"
> "wfs_title" "Cities_3x"
> "gml_featureid" "Name"
> "gml_include_items" "all"
> "wfs_enable_request" "*"
> "wfs_encoding" "UTF-8"
> "wfs_abstract" "Points"
> "wfs_getfeature_formatlist" "geojson"
> END
> TYPE point
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION 'Cities.db'
> DATA 'Cities_3x' – works in Linux
> DATA ‘select * from Cities_3x’ -- required for Windows
> PROJECTION
> "init=epsg:4326"
> END # PROJECTION
> END # LAYER
