[mapserver-users] Default GetCapabilities Version Not Working
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Thu May 17 11:31:50 PDT 2018
Hi Matthew: Looking at the code MapServer 7.0 defaults to 1.3.0 already for GetCapabilties requests – you shouldn’t need that line. That said, it should work… --Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
Sent: Wednesday, May 16, 2018 4:22 PM
To: mapserver-users <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Default GetCapabilities Version Not Working
All,
We are running MapServer version 7.0.1 and attempting to use the MAP > WEB > METADATA > wms_getcapabilities_version configuration value to support GetCapabilities requests that do not supply the VERSION parameter. Unfortunately, even if we do add this value to our mapserver configuration file, we continue to see the following service exception. Any suggestions?
msOWSParseVersionString(): OWS error. Invalid version (). Version must be in the format 'x.y' or 'x.y.z'
Here is our METADATA block:
WEB
METADATA
"wms_enable_request" "GetMap GetCapabilities"
"wms_title" "Some Text"
"wms_abstract" "Some Text"
"wms_onlineresource" "https://our_url?"
"wms_srs" "epsg:4326"
"wms_getcapabilities_version" "1.3.0"
"wms_connectiontimeout" "180"
END
END
Thanks,
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180517/b3bc16bc/attachment.html>
