[mapserver-users] mapserver 6 mapcache 1.6 tileindex limit
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 23 11:16:15 PDT 2018
Hi Sebastiano,
There shouldn't be any limit (there was a limit in pre-MapServer 5
versions, of a MAXLAYERS, but that was removed).
For testing I always use shp2img commandline utility on the mapfile, to
get the exact error, with the switch:
-map_debug 3
That should likely return an error for your problem index record like:
Unable to access file. \ms4w\apps\tileindex\ttt.tif
It might also be good to share your exact error here to everyone. (if
it is a lot of text, be sure to paste the link instead here, from
https://pastebin.com/
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2018-10-23 10:52 AM, Sebastiano Laini wrote:
> Hi All,
> Since I reimaged the server and installed CentOS 7 (previously was
> centOS 6) , mapserver 6.2.1 and Mapcache 1.6 (previously was v.1) I
> can’t make work my .MAP file that call inside the Raster tileindex of
> the whole UK (created with GDAL).
> The only way to make it works it to create a new index with less images,
> and if I go over that limit mapserver doesn’t load the layer.
> It’s a settings that I can change within mapserver or is related with
> something else?
> Sebastiano Laini
> Web Developer
> Buchanan Computing
