[mapserver-users] mapserver 6 mapcache 1.6 tileindex limit
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Oct 23 11:46:37 PDT 2018
Hi Sebastiano,
Excuse me if I guess wrong, but do you mean that you have thousands or tens of thousands of images in the tileindex and you try to load the whole UK on the map? It means that Mapserver should open every image and pick a pixel or two from each of the thousands of files. It may work but it is not the right way to do it. The right way is to make a scale dependent layer group and use some other imagery with much bigger pixel size and much less files for small scales. Switch to full resolution images when it is enough to open about 20 files for filling up the screen. And make sure that your images are tiled and they have overviews.
Slides 1-18 about preparing rasters for Geoserver are also valid for Mapserver.
https://www.slideshare.net/geosolutions/gs-steroids-sgiannecfoss4g20130103
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Jeff McKenna
Lähetetty: 23. lokakuuta 2018 21:16
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] mapserver 6 mapcache 1.6 tileindex limit
Hi Sebastiano,
There shouldn't be any limit (there was a limit in pre-MapServer 5 versions, of a MAXLAYERS, but that was removed).
For testing I always use shp2img commandline utility on the mapfile, to get the exact error, with the switch:
-map_debug 3
That should likely return an error for your problem index record like:
Unable to access file. \ms4w\apps\tileindex\ttt.tif
It might also be good to share your exact error here to everyone. (if it is a lot of text, be sure to paste the link instead here, from https://pastebin.com/
-jeff
Jeff McKenna
MapServer Consulting and Training Services https://gatewaygeomatics.com/
On 2018-10-23 10:52 AM, Sebastiano Laini wrote:
> Hi All,
> Since I reimaged the server and installed CentOS 7 (previously was
> centOS 6) , mapserver 6.2.1 and Mapcache 1.6 (previously was v.1) I
> can’t make work my .MAP file that call inside the Raster tileindex of
> the whole UK (created with GDAL).
> The only way to make it works it to create a new index with less
> images, and if I go over that limit mapserver doesn’t load the layer.
> It’s a settings that I can change within mapserver or is related with
> something else?
> Sebastiano Laini
> Web Developer
> Buchanan Computing
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
