[mapserver-users] LAYER with CONNECTIONTYPE UNION fails catastrophically when asked to reproject
Julian Hollingbery
julian at northtech.dk
Wed Sep 12 07:43:09 PDT 2018
Hi list,
I have run into something which puzzles me. I have configured a WMS using a MAP file with three layers: dtk_skaermkort, dtk_skaermkort_3096 and dtk_skaermkort_1548. The two latter expose TIFFs via a tile index in a shape file. Data is in EPSG:25832. The first layer uses CONNECTIONTYPE UNION to show the aggregate of the other two layers. This works *as long as I stay in the native projection*. However, this fails:
http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/topo_skaermkort/topo_skaermkort_mailinglist.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-280235,5874930,649671,6549730&CRS=EPSG:25833&WIDTH=867&HEIGHT=629&LAYERS=dtk_skaermkort&STYLES=&FORMAT=image/png
With a horrible Apache HTTP 500 (which I can find no trace of in /var/log/apache2/error.log...)
even though these succeed:
http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/topo_skaermkort/topo_skaermkort_mailinglist.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-280235,5874930,649671,6549730&CRS=EPSG:25833&WIDTH=867&HEIGHT=629&LAYERS=dtk_skaermkort_3096&STYLES=&FORMAT=image/png
and
http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/topo_skaermkort/topo_skaermkort_mailinglist.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-280235,5874930,649671,6549730&CRS=EPSG:25833&WIDTH=867&HEIGHT=629&LAYERS=dtk_skaermkort_1548&STYLES=&FORMAT=image/png
What have I done wrong?
Sample data: https://www.dropbox.com/s/gw8h8lrwwb0gltz/data.zip?dl=0
Map file:
MAP
NAME "topo_skaermkort"
EXTENT 120000 5900000 1000000 6500000
MAXSIZE 10000
STATUS ON
UNITS METERS
DEBUG 5
SHAPEPATH "/mapserver/data/skaermkort_ok"
CONFIG "ON_MISSING_DATA" "LOG"
CONFIG "MS_ERRORFILE" "maperror_topo_skaermkort_local.txt"
PROJECTION
"init=epsg:25832"
END
WEB
IMAGEPATH "/mapserver/data/skaermkort_ok/originalt/"
METADATA
"wms_title" "DTK/Skærmkort"
"wms_srs" "EPSG:4326 EPSG:4258 EPSG:25832 EPSG:25833 EPSG:32632 EPSG:32633 EPSG:4093 EPSG:4094 EPSG:4095 EPSG:4096 EPSG:3395 EPSG:3857"
"wms_bbox_extended" "TRUE"
"wms_getmap_formatlist" "image/jpeg,image/png"
"ows_enable_request" "* !GetFeatureInfo"
"wms_encoding" "utf-8"
END
END
LAYER
NAME "dtk_skaermkort"
STATUS ON
TYPE raster
PROCESSING "RESAMPLE=BILINEAR"
CONNECTION "s3096,s1548,s774,s387,s193,s96,s48,s24,s12,s6,s3,s1,s07"
METADATA
"wms_title" "dtk_skaermkort"
"wms_srs" "epsg:25832"
"wms_group_title" "dtk_skaermkort"
END
END
LAYER
GROUP "dtk_skaermkort"
NAME "s3096"
TILEINDEX "originalt/s3096/s3096x.shp"
TILEITEM "location"
MINSCALEDENOM 1201748.867
MAXSCALEDENOM 30000000
STATUS OFF
TYPE raster
METADATA
"wms_title" "s3096"
"wms_enable_request" "!GetCapabilities"
END
END
LAYER
NAME "s1548"
TILEINDEX "originalt/s1548/s1548x.shp"
TILEITEM "location"
MINSCALEDENOM 600874.809
MAXSCALEDENOM 1201748.866
STATUS OFF
TYPE raster
METADATA
"wms_title" "s1548"
END
END
END
Kind Regards,
/julian
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180912/a8f199c2/attachment.html>
