[mapserver-users] LAYER with CONNECTIONTYPE UNION fails catastrophically when asked to reproject
Seth G
sethg at geographika.co.uk
Wed Sep 12 23:50:20 PDT 2018
Possibly unrelated, but would having a GROUP Name and LAYER Name set to
the same value (dtk_skaermkort) cause an issue?Maybe try setting all the STATUS settings to OFF also.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Wed, Sep 12, 2018, at 4:43 PM, Julian Hollingbery wrote:
> Hi list,
> I have run into something which puzzles me. I have configured a WMS
> using a MAP file with three layers: dtk_skaermkort,
> dtk_skaermkort_3096 and dtk_skaermkort_1548. The two latter expose
> TIFFs via a tile index in a shape file. Data is in EPSG:25832. The
> first layer uses CONNECTIONTYPE UNION to show the aggregate of the
> other two layers. This works **as long as I stay in the native
> projection**. However, this fails:> http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/topo_skaermkort/topo_skaermkort_mailinglist.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-280235,5874930,649671,6549730&CRS=EPSG:25833&WIDTH=867&HEIGHT=629&LAYERS=dtk_skaermkort&STYLES=&FORMAT=image/png> With a horrible Apache HTTP 500 (which I can find no trace of in
> /var/log/apache2/error.log…)>
> even though these succeed:
> http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/topo_skaermkort/topo_skaermkort_mailinglist.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-280235,5874930,649671,6549730&CRS=EPSG:25833&WIDTH=867&HEIGHT=629&LAYERS=dtk_skaermkort_3096&STYLES=&FORMAT=image/png> and
> http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/topo_skaermkort/topo_skaermkort_mailinglist.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-280235,5874930,649671,6549730&CRS=EPSG:25833&WIDTH=867&HEIGHT=629&LAYERS=dtk_skaermkort_1548&STYLES=&FORMAT=image/png>
> What have I done wrong?
> Sample data: https://www.dropbox.com/s/gw8h8lrwwb0gltz/data.zip?dl=0> Map file:
> MAP
> NAME "topo_skaermkort"
> EXTENT 120000 5900000 1000000 6500000
> MAXSIZE 10000
> STATUS ON
> UNITS METERS
> DEBUG 5
> SHAPEPATH "/mapserver/data/skaermkort_ok"
> CONFIG "ON_MISSING_DATA" "LOG"
> CONFIG "MS_ERRORFILE" "maperror_topo_skaermkort_local.txt"
> PROJECTION
> "init=epsg:25832"
> END
> WEB
> IMAGEPATH "/mapserver/data/skaermkort_ok/originalt/"
> METADATA
> "wms_title" "DTK/Skærmkort"
> "wms_srs" "EPSG:4326 EPSG:4258 EPSG:25832 EPSG:25833
> EPSG:32632 EPSG:32633 EPSG:4093 EPSG:4094 EPSG:4095
> EPSG:4096 EPSG:3395 EPSG:3857"> "wms_bbox_extended" "TRUE"
> "wms_getmap_formatlist" "image/jpeg,image/png"
> "ows_enable_request" "* !GetFeatureInfo"
> "wms_encoding" "utf-8"
> END
> END
> LAYER
> NAME "dtk_skaermkort"
> STATUS ON
> TYPE raster
> PROCESSING "RESAMPLE=BILINEAR"
> CONNECTION
> "s3096,s1548,s774,s387,s193,s96,s48,s24,s12,s6,s3,s1,s07"> METADATA
> "wms_title" "dtk_skaermkort"
> "wms_srs" "epsg:25832"
> "wms_group_title" "dtk_skaermkort"
> END
> END
> LAYER
> GROUP "dtk_skaermkort"
> NAME "s3096"
> TILEINDEX "originalt/s3096/s3096x.shp"
> TILEITEM "location"
> MINSCALEDENOM 1201748.867
> MAXSCALEDENOM 30000000
> STATUS OFF
> TYPE raster
> METADATA
> "wms_title" "s3096"
> "wms_enable_request" "!GetCapabilities"
> END
> END
> LAYER
> NAME "s1548"
> TILEINDEX "originalt/s1548/s1548x.shp"
> TILEITEM "location"
> MINSCALEDENOM 600874.809
> MAXSCALEDENOM 1201748.866
> STATUS OFF
> TYPE raster
> METADATA
> "wms_title" "s1548"
> END
> END
> END
> Kind Regards,
> /julian
> _________________________________________________
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180913/0ce2dd42/attachment-0001.html>
