[mapserver-users] Mapcache instruction
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Sep 20 05:39:26 PDT 2018
Lars,
Why did you use {z}/{x}-{y} in the filename?
I was probably wrong when I tell to create the sqlite file, this is true
for mbtiles though.
Y.
Le jeu. 20 sept. 2018 à 14:24, <lars.schylberg at blixtmail.se> a écrit :
> I also ran into the problem of running out of i-nodes last year.
> Here is the configuration I have with a sqlite cache:
> <cache name="Nordic_sqlite" type="sqlite3">
> <dbfile>/data/mapcache/{grid}/{tileset}/{z}/{x}-{y}.sqlite3</dbfile>
> <xcount>10000</xcount>
> <ycount>10000</ycount>
> <pragma name="max_page_count">1573741823</pragma>
> </cache>
> I guess the pragma thing is described in the documentation.
> xcount and ycount describes how much You want to store in each sqlite db
> file before it creates a new db file.
> mapcache is creating the db files automatically. So seeding a large area
> You end up with many sqlite db files that all work together.
> This has worked really good for our use case.
> Lars Schylberg
> September 20, 2018 1:24 PM, "Yves Jacolin" <yves.jacolin at camptocamp.com
> <yves.jacolin at camptocamp.com?to=%22Yves%20Jacolin%22%20%3Cyves.jacolin at camptocamp.com%3E>>
> wrote:
> Here a short tuto from my personal notes:
> 1. create a cache entry in your mapcache file
> <cache name="mbtiles" type="sqlite3"> <dbfile>/var/www/osm_google.db</dbfile> </cache>
> 2. create a empty sqlite file
> - run sqlite3
> - run this commande inside sqlite3: ".save filename.db" (without ")
> 3. use this cache in your settings
> You don't need MySQL or PostgreSQL, only sqlite3 and its dependencies.
> Path used in my example for cache block are for Unix like system, you
> should adapt it for Windows : c:/....
> Y.
> Le jeu. 20 sept. 2018 à 13:07, Sebastiano Laini <
> Sebastiano.Laini at buchanancomputing.co.uk> a écrit :
> Hi all,
> We have a MapCache setup with “disk_cache” but we are running out of
> Inodes when I try to seed the whole UK with projection 27700.
> I was thinking to propose to my supervisor to use the “SQLite Caches” but
> I don’t know how it works. Can someone guide me through the process of
> setup MapCache with this type of cache? And if I need some dependency, we
> use PostgreSQL in our server so I assume I need to install also MySQL.
> I’ve already read the documentation but still I have doubt about the db
> part, how to create the db and locate it. I never use SQLite, just
> PostgreSQL.
> Regards;
> Sebastiano.
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Training and support manager
> Camptocamp
> Bâtiment le Dauphin - 1er étage
> 18 rue du Lac Saint André
> 73382 Le Bourget-du Lac
> Tel (France) : +33 4 58 48 20 43
> Tel (Switzerland) : +41 21 619 10 43
> Mob. : +33 6 18 75 42 21
> email : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
Camptocamp
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180920/90d3a301/attachment.html>
