[mapserver-users] mapserver 7.4 beta phpng build error
Seth G
sethg at geographika.co.uk
Wed Apr 3 15:34:09 PDT 2019
There are now 2 PHP MapScripts. See https://mapserver.org/development/rfc/ms-rfc-117.html for details.
The "native" one has been updated to work with PHP7 in the MapServer 7.4 release, and also a new SWIG based PHP MapScript is now available. The first does not require SWIG, the latter does.
These can be build by setting the following 2 flags:
WITH_PHP "Enable PHP mapscript support" OFF
WITH_PHPNG "Enable PHPNG (SWIG) mapscript support" OFF
web:http://geographika.co.uk
twitter: @geographika
On Thu, Apr 4, 2019, at 12:06 AM, Richard Greenwood wrote:
> On Wed, Apr 3, 2019 at 10:39 AM Seth G <sethg at geographika.co.uk> wrote:
>> __
>> Hi Richard,
>> If you had previous errors it may be best to delete the whole /rwg/src/mapserver/build/ and start the build from scratch again.
> I did do that.
>> Also to note is PHP 7 support was only added in SWIG-3.0.11. I'm trying to get this set up on Travis and can do so with the following command:
>> sudo wget http://prdownloads.sourceforge.net/swig/swig-3.0.12.tar.gz
>> tar xf swig-3.0.12.tar.gz
>> cd swig-3.0.12 && ./configure --prefix=/usr && make && sudo make install
>> swig -version
> Not sure I'm following you. Do I need to have swig installed? I don't.
>> I've run into further errors but mapscriptPHP7_wrap.c is created at least.
> Again, not sure I'm following you. Is mapscriptPHP7_wrap.c supposed to be in the source files that I download or git clone, or is it created in the build process?
>> Seth
>> On Wed, Apr 3, 2019, at 4:11 AM, Richard Greenwood wrote:
>>> I get the following error:
>>> Building C object mapscript/phpng/CMakeFiles/php_mapscriptng.dir/mapscriptPHP7_wrap.c.o
>>> cc: error: /rwg/src/mapserver/build/mapscript/phpng/mapscriptPHP7_wrap.c: No such file or directory
>>> cc: fatal error: no input files
>>> If i'm reading the error message correctly it's not finding "mapscriptPHP7_wrap.c". I don't have "mapscriptPHP7_wrap.c". I tried the file at https://github.com/mapserver/mapserver/releases/tag/rel-7-4-0-beta1
>>> as well as git cloning.
>>> I'm not well versed with this stuff so apologizes in advanced if I'm missing the obvious.
>>> Rich
>>> Richard W. Greenwood, PLS
>>> www.greenwoodmap.com
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190403/e03daded/attachment.html>
