[mapserver-users] mapserver 7.4 beta phpng build error
Seth G
sethg at geographika.co.uk
Sat Apr 20 02:47:38 PDT 2019
Hi Richard / all,
The new PHP SWIG bindings seem to be fine to compile locally, and as they are part of ms4w, and I believe the Debian builds are working well.
I've not been able to get them to build on Travis, not has AlexanderGabriel who set these up originally - see https://github.com/mapserver/mapserver/pull/5675
If anyone has any suggestions after looking at the logs of the Travis output it would be appreciated - https://api.travis-ci.org/v3/job/515453218/log.txt
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, Apr 4, 2019, at 4:05 PM, Seth G wrote:
> mapscriptPHP7_wrap.c is created by SWIG so won't exist unless SWIG runs successfully.
> I'm trying to get it setup on Travis so you can see a full build output, but was getting errors.
> You can have a look at https://travis-ci.org/geographika/mapserver/jobs/515238229 - https://api.travis-ci.org/v3/job/515238229/log.txt which may help - mapscriptPHP7_wrap.c is created but not currently compiling afterwards.
> On Thu, Apr 4, 2019, at 4:41 AM, Richard Greenwood wrote:
>> Seth,
>> I understand that there are two php versions and the native one builds fine for me. But the swig one (phpng) does not. I installed swig 3.0.12. My build fails with error:
>> /rwg/src/mapserver-branch-7-4/build/mapscript/phpng/mapscriptPHP7_wrap.c: No such file or directory
>> I can't find the file mapscriptPHP7_wrap.c
>> Thanks,
>> Rich
>> On Wed, Apr 3, 2019 at 4:34 PM Seth G <sethg at geographika.co.uk> wrote:
>>> __
>>> There are now 2 PHP MapScripts. See https://mapserver.org/development/rfc/ms-rfc-117.html for details.
>>> The "native" one has been updated to work with PHP7 in the MapServer 7.4 release, and also a new SWIG based PHP MapScript is now available. The first does not require SWIG, the latter does.
>>> These can be build by setting the following 2 flags:
>>> WITH_PHP "Enable PHP mapscript support" OFF
>>> WITH_PHPNG "Enable PHPNG (SWIG) mapscript support" OFF
>>> On Thu, Apr 4, 2019, at 12:06 AM, Richard Greenwood wrote:
>>>> On Wed, Apr 3, 2019 at 10:39 AM Seth G <sethg at geographika.co.uk> wrote:
>>>>> __
>>>>> Hi Richard,
>>>>> If you had previous errors it may be best to delete the whole /rwg/src/mapserver/build/ and start the build from scratch again.
>>>> I did do that.
>>>>> Also to note is PHP 7 support was only added in SWIG-3.0.11. I'm trying to get this set up on Travis and can do so with the following command:
>>>>> sudo wget http://prdownloads.sourceforge.net/swig/swig-3.0.12.tar.gz
>>>>> tar xf swig-3.0.12.tar.gz
>>>>> cd swig-3.0.12 && ./configure --prefix=/usr && make && sudo make install
>>>>> swig -version
>>>> Not sure I'm following you. Do I need to have swig installed? I don't.
>>>>> I've run into further errors but mapscriptPHP7_wrap.c is created at least.
>>>> Again, not sure I'm following you. Is mapscriptPHP7_wrap.c supposed to be in the source files that I download or git clone, or is it created in the build process?
>>>>> Seth
>>>>> On Wed, Apr 3, 2019, at 4:11 AM, Richard Greenwood wrote:
>>>>>> I get the following error:
>>>>>> Building C object mapscript/phpng/CMakeFiles/php_mapscriptng.dir/mapscriptPHP7_wrap.c.o
>>>>>> cc: error: /rwg/src/mapserver/build/mapscript/phpng/mapscriptPHP7_wrap.c: No such file or directory
>>>>>> cc: fatal error: no input files
>>>>>> If i'm reading the error message correctly it's not finding "mapscriptPHP7_wrap.c". I don't have "mapscriptPHP7_wrap.c". I tried the file at https://github.com/mapserver/mapserver/releases/tag/rel-7-4-0-beta1
>>>>>> as well as git cloning.
>>>>>> I'm not well versed with this stuff so apologizes in advanced if I'm missing the obvious.
>>>>>> Rich
>>>>>> Richard W. Greenwood, PLS
>>>>>> www.greenwoodmap.com
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190420/a1e3ed97/attachment.html>
