[mapserver-users] mapserver 7.4 beta phpng build error
Richard Greenwood
richard.greenwood at gmail.com
Sun Apr 21 06:17:54 PDT 2019
Seth,
I don't think this helps your issue with Travis, but just for the record, I
still can't get PHPNG to build on Ubuntu 18.04. The legacy PHP builds fine.
I've tried building PHPNG on two Ubuntu 18.04 machines with slightly
different PHP configurations (one has PHP 7.2 from the Ubuntu repo, the
other has PHP 7.2 from deb.sury.org). On both I get:
Building C object
mapscript/phpng/CMakeFiles/php_mapscriptng.dir/mapscriptPHP7_wrap.c.o
cc: error:
/rwg/src/mapserver-7.4.0-beta2/build2/mapscript/phpng/mapscriptPHP7_wrap.c:
No such file or directory
cc: fatal error: no input files
ccmake issues the following warnings:
PHPUNIT_EXECUTABLE */usr/local/bin/phpunit
PHP_CONFIG_EXECUTABLE */usr/bin/php-config
PHP_LIBRARY *PHP_LIBRARY-NOTFOUND
I've taken a few guesses at setting paths for PHP_LIBRARY but no luck and I
don't really know what I'm doing.
Rich
On Sat, Apr 20, 2019 at 3:47 AM Seth G <sethg at geographika.co.uk> wrote:
> Hi Richard / all,
> The new PHP SWIG bindings seem to be fine to compile locally, and as they
> are part of ms4w, and I believe the Debian builds are working well.
> I've not been able to get them to build on Travis, not has
> AlexanderGabriel who set these up originally - see
> https://github.com/mapserver/mapserver/pull/5675
> If anyone has any suggestions after looking at the logs of the Travis
> output it would be appreciated -
> https://api.travis-ci.org/v3/job/515453218/log.txt
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Thu, Apr 4, 2019, at 4:05 PM, Seth G wrote:
> mapscriptPHP7_wrap.c is created by SWIG so won't exist unless SWIG runs
> successfully.
> I'm trying to get it setup on Travis so you can see a full build output,
> but was getting errors.
> You can have a look at
> https://travis-ci.org/geographika/mapserver/jobs/515238229 -
> https://api.travis-ci.org/v3/job/515238229/log.txt which may help -
> mapscriptPHP7_wrap.c is created but not currently compiling afterwards.
> On Thu, Apr 4, 2019, at 4:41 AM, Richard Greenwood wrote:
> Seth,
> I understand that there are two php versions and the native one builds
> fine for me. But the swig one (phpng) does not. I installed swig 3.0.12. My
> build fails with error:
> /rwg/src/mapserver-branch-7-4/build/mapscript/phpng/mapscriptPHP7_wrap.c:
> I can't find the file mapscriptPHP7_wrap.c
> Thanks,
> Rich
> On Wed, Apr 3, 2019 at 4:34 PM Seth G <sethg at geographika.co.uk> wrote:
> There are now 2 PHP MapScripts. See
> https://mapserver.org/development/rfc/ms-rfc-117.html for details.
> The "native" one has been updated to work with PHP7 in the MapServer 7.4
> release, and also a new SWIG based PHP MapScript is now available. The
> first does not require SWIG, the latter does.
> These can be build by setting the following 2 flags:
> WITH_PHP "Enable PHP mapscript support" OFF
> WITH_PHPNG "Enable PHPNG (SWIG) mapscript support" OFF
> On Thu, Apr 4, 2019, at 12:06 AM, Richard Greenwood wrote:
> On Wed, Apr 3, 2019 at 10:39 AM Seth G <sethg at geographika.co.uk> wrote:
> Hi Richard,
> If you had previous errors it may be best to delete the whole
> /rwg/src/mapserver/build/ and start the build from scratch again.
> I did do that.
> Also to note is PHP 7 support was only added in SWIG-3.0.11. I'm trying to
> get this set up on Travis and can do so with the following command:
> sudo wget http://prdownloads.sourceforge.net/swig/swig-3.0.12.tar.gz
> tar xf swig-3.0.12.tar.gz
> cd swig-3.0.12 && ./configure --prefix=/usr && make && sudo make install
> swig -version
> Not sure I'm following you. Do I need to have swig installed? I don't.
> I've run into further errors but mapscriptPHP7_wrap.c is created at least.
> Again, not sure I'm following you. Is mapscriptPHP7_wrap.c supposed to be
> in the source files that I download or git clone, or is it created in the
> build process?
> Seth
> On Wed, Apr 3, 2019, at 4:11 AM, Richard Greenwood wrote:
> I get the following error:
> Building C object
> cc: error: /rwg/src/mapserver/build/mapscript/phpng/mapscriptPHP7_wrap.c:
> If i'm reading the error message correctly it's not finding
> "mapscriptPHP7_wrap.c". I don't have "mapscriptPHP7_wrap.c". I tried the
> file at
> https://github.com/mapserver/mapserver/releases/tag/rel-7-4-0-beta1
> as well as git cloning.
> I'm not well versed with this stuff so apologizes in advanced if I'm
> missing the obvious.
> Rich
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190421/49452b5f/attachment.html>
