[mapserver-users] mapserver 7.4 beta phpng build error
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Sun Apr 21 07:36:21 PDT 2019
Rich,
Do you have the php-dev package installed?
-Steve W
On 4/21/2019 9:17 AM, Richard Greenwood wrote:
> Seth,
> I don't think this helps your issue with Travis, but just for the
> record, I still can't get PHPNG to build on Ubuntu 18.04. The legacy
> PHP builds fine. I've tried building PHPNG on two Ubuntu 18.04
> machines with slightly different PHP configurations (one has PHP 7.2
> from the Ubuntu repo, the other has PHP 7.2 from deb.sury.org
> <http://deb.sury.org>). On both I get:
> Building C object
> mapscript/phpng/CMakeFiles/php_mapscriptng.dir/mapscriptPHP7_wrap.c.o
> cc: error:
> /rwg/src/mapserver-7.4.0-beta2/build2/mapscript/phpng/mapscriptPHP7_wrap.c:
> No such file or directory
> cc: fatal error: no input files
> ccmake issues the following warnings:
> PHPUNIT_EXECUTABLE */usr/local/bin/phpunit
> PHP_CONFIG_EXECUTABLE */usr/bin/php-config
> PHP_LIBRARY *PHP_LIBRARY-NOTFOUND
> I've taken a few guesses at setting paths for PHP_LIBRARY but no luck
> and I don't really know what I'm doing.
> Rich
> On Sat, Apr 20, 2019 at 3:47 AM Seth G <sethg at geographika.co.uk
> <mailto:sethg at geographika.co.uk>> wrote:
> Hi Richard / all,
> The new PHP SWIG bindings seem to be fine to compile locally, and
> as they are part of ms4w, and I believe the Debian builds are
> working well.
> I've not been able to get them to build on Travis, not has
> AlexanderGabriel who set these up originally - see
> https://github.com/mapserver/mapserver/pull/5675
> If anyone has any suggestions after looking at the logs of the
> Travis output it would be appreciated -
> https://api.travis-ci.org/v3/job/515453218/log.txt
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Thu, Apr 4, 2019, at 4:05 PM, Seth G wrote:
>> mapscriptPHP7_wrap.c is created by SWIG so won't exist unless
>> SWIG runs successfully.
>> I'm trying to get it setup on Travis so you can see a full build
>> output, but was getting errors.
>> You can have a look at
>> https://travis-ci.org/geographika/mapserver/jobs/515238229 -
>> https://api.travis-ci.org/v3/job/515238229/log.txt which may help
>> - mapscriptPHP7_wrap.c is created but not currently compiling
>> afterwards.
>> On Thu, Apr 4, 2019, at 4:41 AM, Richard Greenwood wrote:
>>> Seth,
>>> I understand that there are two php versions and the native one
>>> builds fine for me. But the swig one (phpng) does not. I
>>> installed swig 3.0.12. My build fails with error:
>>> /rwg/src/mapserver-branch-7-4/build/mapscript/phpng/mapscriptPHP7_wrap.c:
>>> I can't find the file mapscriptPHP7_wrap.c
>>> Thanks,
>>> Rich
>>> On Wed, Apr 3, 2019 at 4:34 PM Seth G <sethg at geographika.co.uk
>>> There are now 2 PHP MapScripts. See
>>> https://mapserver.org/development/rfc/ms-rfc-117.html for
>>> details.
>>> The "native" one has been updated to work with PHP7 in the
>>> MapServer 7.4 release, and also a new SWIG based PHP
>>> MapScript is now available. The first does not require SWIG,
>>> the latter does.
>>> These can be build by setting the following 2 flags:
>>> WITH_PHP "Enable PHP mapscript support" OFF
>>> WITH_PHPNG "Enable PHPNG (SWIG) mapscript support" OFF
>>> On Thu, Apr 4, 2019, at 12:06 AM, Richard Greenwood wrote:
>>>> On Wed, Apr 3, 2019 at 10:39 AM Seth G
>>>> <sethg at geographika.co.uk <mailto:sethg at geographika.co.uk>>
>>>> wrote:
>>>> Hi Richard,
>>>> If you had previous errors it may be best to delete the
>>>> whole /rwg/src/mapserver/build/ and start the build
>>>> from scratch again.
>>>> I did do that.
>>>> Also to note is PHP 7 support was only added in
>>>> SWIG-3.0.11. I'm trying to get this set up on Travis
>>>> and can do so with the following command:
>>>> sudo wget
>>>> http://prdownloads.sourceforge.net/swig/swig-3.0.12.tar.gz
>>>> tar xf swig-3.0.12.tar.gz
>>>> cd swig-3.0.12 && ./configure --prefix=/usr && make &&
>>>> sudo make install
>>>> swig -version
>>>> Not sure I'm following you. Do I need to have swig
>>>> installed? I don't.
>>>> I've run into further errors but mapscriptPHP7_wrap.c
>>>> is created at least.
>>>> Again, not sure I'm following you. Is mapscriptPHP7_wrap.c
>>>> supposed to be in the source files that I download or git
>>>> clone, or is it created in the build process?
>>>> Seth
>>>> On Wed, Apr 3, 2019, at 4:11 AM, Richard Greenwood wrote:
>>>>> I get the following error:
>>>>> Building C object
>>>>> cc: error:
>>>>> /rwg/src/mapserver/build/mapscript/phpng/mapscriptPHP7_wrap.c:
>>>>> If i'm reading the error message correctly it's not
>>>>> finding "mapscriptPHP7_wrap.c". I don't have
>>>>> "mapscriptPHP7_wrap.c". I tried the file at
>>>>> https://github.com/mapserver/mapserver/releases/tag/rel-7-4-0-beta1
>>>>> as well as git cloning.
>>>>> I'm not well versed with this stuff so apologizes in
>>>>> advanced if I'm missing the obvious.
>>>>> Rich
>>>>> Richard W. Greenwood, PLS
>>>>> www.greenwoodmap.com <http://www.greenwoodmap.com>
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> <mailto:mapserver-users at lists.osgeo.org>
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
