[mapserver-users] mapserver 7.4 beta phpng build error
Richard Greenwood
richard.greenwood at gmail.com
Sun Apr 21 13:49:15 PDT 2019
Yes I do:
php7.2-dev/bionic,now 7.2.17-1+ubuntu18.04.1+deb.sury.org+3 amd64 [
installed]
The non-SWIG version builds and runs fine.
And I have SWIG Version 3.0.12 installed.
Thanks,
Rich
On Sun, Apr 21, 2019 at 8:36 AM Stephen Woodbridge <
stephenwoodbridge37 at gmail.com> wrote:
> Rich,
> Do you have the php-dev package installed?
> -Steve W
> On 4/21/2019 9:17 AM, Richard Greenwood wrote:
> > Seth,
> > I don't think this helps your issue with Travis, but just for the
> > record, I still can't get PHPNG to build on Ubuntu 18.04. The legacy
> > PHP builds fine. I've tried building PHPNG on two Ubuntu 18.04
> > machines with slightly different PHP configurations (one has PHP 7.2
> > from the Ubuntu repo, the other has PHP 7.2 from deb.sury.org
> > <http://deb.sury.org>). On both I get:
> > Building C object
> > mapscript/phpng/CMakeFiles/php_mapscriptng.dir/mapscriptPHP7_wrap.c.o
> > cc: error:
> /rwg/src/mapserver-7.4.0-beta2/build2/mapscript/phpng/mapscriptPHP7_wrap.c:
> > No such file or directory
> > cc: fatal error: no input files
> > ccmake issues the following warnings:
> > PHPUNIT_EXECUTABLE */usr/local/bin/phpunit
> > PHP_CONFIG_EXECUTABLE */usr/bin/php-config
> > PHP_LIBRARY *PHP_LIBRARY-NOTFOUND
> > I've taken a few guesses at setting paths for PHP_LIBRARY but no luck
> > and I don't really know what I'm doing.
> > Rich
> > On Sat, Apr 20, 2019 at 3:47 AM Seth G <sethg at geographika.co.uk
> > <mailto:sethg at geographika.co.uk>> wrote:
> > Hi Richard / all,
> > The new PHP SWIG bindings seem to be fine to compile locally, and
> > as they are part of ms4w, and I believe the Debian builds are
> > working well.
> > I've not been able to get them to build on Travis, not has
> > AlexanderGabriel who set these up originally - see
> > https://github.com/mapserver/mapserver/pull/5675
> > If anyone has any suggestions after looking at the logs of the
> > Travis output it would be appreciated -
> > https://api.travis-ci.org/v3/job/515453218/log.txt
> > Seth
> > web:http://geographika.co.uk
> > twitter: @geographika
> > On Thu, Apr 4, 2019, at 4:05 PM, Seth G wrote:
> >> mapscriptPHP7_wrap.c is created by SWIG so won't exist unless
> >> SWIG runs successfully.
> >> I'm trying to get it setup on Travis so you can see a full build
> >> output, but was getting errors.
> >> You can have a look at
> >> https://travis-ci.org/geographika/mapserver/jobs/515238229 -
> >> https://api.travis-ci.org/v3/job/515238229/log.txt which may help
> >> - mapscriptPHP7_wrap.c is created but not currently compiling
> >> afterwards.
> >> On Thu, Apr 4, 2019, at 4:41 AM, Richard Greenwood wrote:
> >>> Seth,
> >>> I understand that there are two php versions and the native one
> >>> builds fine for me. But the swig one (phpng) does not. I
> >>> installed swig 3.0.12. My build fails with error:
> /rwg/src/mapserver-branch-7-4/build/mapscript/phpng/mapscriptPHP7_wrap.c:
> >>> I can't find the file mapscriptPHP7_wrap.c
> >>> Thanks,
> >>> Rich
> >>> On Wed, Apr 3, 2019 at 4:34 PM Seth G <sethg at geographika.co.uk
> >>> There are now 2 PHP MapScripts. See
> >>> https://mapserver.org/development/rfc/ms-rfc-117.html for
> >>> details.
> >>> The "native" one has been updated to work with PHP7 in the
> >>> MapServer 7.4 release, and also a new SWIG based PHP
> >>> MapScript is now available. The first does not require SWIG,
> >>> the latter does.
> >>> These can be build by setting the following 2 flags:
> >>> WITH_PHP "Enable PHP mapscript support" OFF
> >>> WITH_PHPNG "Enable PHPNG (SWIG) mapscript support" OFF
> >>> On Thu, Apr 4, 2019, at 12:06 AM, Richard Greenwood wrote:
> >>>> On Wed, Apr 3, 2019 at 10:39 AM Seth G
> >>>> <sethg at geographika.co.uk <mailto:sethg at geographika.co.uk>>
> >>>> wrote:
> >>>> Hi Richard,
> >>>> If you had previous errors it may be best to delete the
> >>>> whole /rwg/src/mapserver/build/ and start the build
> >>>> from scratch again.
> >>>> I did do that.
> >>>> Also to note is PHP 7 support was only added in
> >>>> SWIG-3.0.11. I'm trying to get this set up on Travis
> >>>> and can do so with the following command:
> >>>> sudo wget
> http://prdownloads.sourceforge.net/swig/swig-3.0.12.tar.gz
> >>>> tar xf swig-3.0.12.tar.gz
> >>>> cd swig-3.0.12 && ./configure --prefix=/usr && make &&
> >>>> sudo make install
> >>>> swig -version
> >>>> Not sure I'm following you. Do I need to have swig
> >>>> installed? I don't.
> >>>> I've run into further errors but mapscriptPHP7_wrap.c
> >>>> is created at least.
> >>>> Again, not sure I'm following you. Is mapscriptPHP7_wrap.c
> >>>> supposed to be in the source files that I download or git
> >>>> clone, or is it created in the build process?
> >>>> Seth
> >>>> On Wed, Apr 3, 2019, at 4:11 AM, Richard Greenwood wrote:
> >>>>> I get the following error:
> >>>>> Building C object
> >>>>> cc: error:
> /rwg/src/mapserver/build/mapscript/phpng/mapscriptPHP7_wrap.c:
> >>>>> If i'm reading the error message correctly it's not
> >>>>> finding "mapscriptPHP7_wrap.c". I don't have
> >>>>> "mapscriptPHP7_wrap.c". I tried the file at
> https://github.com/mapserver/mapserver/releases/tag/rel-7-4-0-beta1
> >>>>> as well as git cloning.
> >>>>> I'm not well versed with this stuff so apologizes in
> >>>>> advanced if I'm missing the obvious.
> >>>>> Rich
> >>>>> Richard W. Greenwood, PLS
> >>>>> www.greenwoodmap.com <http://www.greenwoodmap.com>
> >>>>> _______________________________________________
> >>>>> mapserver-users mailing list
> >>>>> mapserver-users at lists.osgeo.org
> >>>>> <mailto:mapserver-users at lists.osgeo.org>
> >>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190421/9e6a7595/attachment-0001.html>
