[mapserver-users] MS4W version 4.0.1 released
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 27 02:20:47 PDT 2019
Hi Jan,
Spatialite leverages librttopo for topology-related functions. More
info at https://git.osgeo.org/gitea/rttopo/librttopo
-jeff
On 2019-08-26 7:00 AM, Jan Hartmann wrote:
> Just curious, how can I use the RT Topology library within Mapserver?
> Jan
> On 8/26/2019 11:43 AM, Jeff McKenna wrote:
>> Hello everyone,
>> MS4W 4.0.1 is now available, which contains many security updates, as
>> well as a few important changes. Get it now at https://ms4w.com
>> Please see MS4W's HISTORY.txt for all of the changes, but here are
>> some of the highlights:
>> - upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to
>> today’s 7.6.0-dev (also due to potential XSS vulnerability)
>> - disabled Pixman support in MapServer build, as it prevents Opacity
>> (trac ticket 218)
>> - upgraded PHP to 7.2.21 (trac ticket 213)
>> - upgraded GDAL to 2.4.2 (trac ticket 195)
>> - upgraded Apache HTTP Server to 2.4.41 (trac ticket 206)
>> - upgraded MapCache to today’s 1.9dev (trac ticket 222)
>> - upgraded OpenSSL support to 1.1.1c (trac ticket 191)
>> - upgraded cURL support to 7.65.1
>> - upgraded NetCDF support to 4.7.0 (trac ticket 193)
>> - upgraded GEOS support to 3.7.2 trac ticket 214)
>> - rebuilt RT Topology Library
>> - upgraded libxml2 support to 2.9.9
>> - upgraded Freetype support to 2.10.1
>> - upgraded PostgreSQL support to 11.4 with SSL enabled (ticket 196)
>> - upgraded HDF5 support to 1.10.5
>> - upgraded SQLite support to 3.28.0
>> - rebuilt SpatiaLite support
>> - rebuilt spatialite-tools
>> - upgraded libPNG support to 1.6.37 (trac ticket 221) due to potential
>> vulnerability
>> - upgraded Pixman support to 0.38.4
>> - upgraded Cairo support to 1.16.0
>> - rebuilt Poppler support
>> - upgraded HarfBuzz support to 2.5.3
>> - rebuilt libSVG support
>> - rebuilt libSVG-Cairo support
>> - updated cURL certificates bundle
>> - rebuilt mod_fcgid
>> - rebuilt Apache H264 Streaming Module
>> - upgraded osm2pgsql commandline utility to today’s git master
>> - rebuilt php_ogr extension
>> - upgraded Shapelib support to 1.5.0 (trac ticket 192)
>> - rebuilt shp2tile utility
>> - set “sys_temp_dir” in php.ini (trac ticket 204)
>> - upgraded APR support to 1.7.0
>> - added /Python/Scripts/ to PATH in setenv.bat (trac ticket 225)
>> - copied GDAL’s python module into /Apache/cgi-bin/ (trac ticket 223)
>> - and many more...
>> When installing, it is very important that (if you are using the .zip)
>> your server must have the C++ Redistributable installed on it
>> beforehand: execute the local file /ms4w/tmp/vcredist_x86.exe
>> (alternatively if you use MS4W's setup.exe installer this is done
>> automatically)
>> As always please provide your requests for enhancements and issues
>> through the MS4W tracker (so the feedback is not lost or forgotten):
>> https://ms4w.com/trac/ You can also contact me directly for support.
>> Thank you all for sharing your spatial information with MS4W !!
>> "MS4W: open doors and as well as windows"
>> -jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
