[mapserver-users] removing seamlines along edges of air photos?
    Stephen Woodbridge
    stephenwoodbridge37 at gmail.com
    Fri Dec  6 10:53:46 PST 2019
Mark,
This sounds more like a GDAL question, in that your should probably
cleanup the images first.
A few things come to mind:
1) see if you can use nearblack utility to set the collars to NODATA
2) use gdal_translate with extents to copy only the data and not the collars
3) define a polygon around the good data, the there should be a way to
set everything outside the polygon to NODATA, not sure about the
specific commands to do this, but I believe it is possible.
-Steve W
On 12/6/2019 11:21 AM, Mark Volz wrote:
> Hello,
> I have a single mapfile that contains two layers.  One layer includes
> county wide aerial photography at medium resolution.  The other layer
> contains high resolution aerial photography for select cities in my
> county.  I would like to combine the two layers so that I can have a
> single “maximum resolution available” image service.  Unfortunately,
> the high resolution air photos have a ~30 foot seamline at the edge of
> the air photos.  The seamline is not all the same exact color so I
> cannot set a transparency.
> Question:
> Would specifying an extent on the high resolution imagery allow me to
> cut off the edge of the imagery (thus removing the area where there is
> a seamline)?  Also, I am referencing all of the high resolution images
> through a tile index so is there a way to also specify extents within
> the tile index, or would I need to separate each of the cities into
> different layers?
> Thanks!
> Mark Volz
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
